Home > Help Needed / General Tech Chat > Effects of no exhaust stem seals?
Asphalt
Member #: 1027
Germini, black forrest
Hi!
I get a puff of blue smoke if the engie sat at idle for awhile (at lights p.e.) and I acclerate hard... Also on start-up from cold Iget a puff of blue smoke. But not under normal driving & acceleration...
I didn't fit stem sealsto the exhaust valves - could this be the reason? Also the guides are pretty worn, so the intake seals might have only a limited effect.
Could this be related, or is it rather the rings? :)
Engine is a n/a 998 'junk/spare' enginewith a 12G940, so nothing precious or expensive. I'm not worried. Oil consumption is normal, even when you conider how much oil it pisses on the drive way *hehe!*
It's just - I've never ran a engine without exhaust stem seals... :)
Jan
[X] nail here for new monitor
wng691s clubby
Member #: 9252
Cleethorpes
sounds like stem seals the later rover ones are good. but worn guides will make it smoke too. can i ask why you didnt put any on the exhaust valves
Done now needs redoing lol
haimesyboi
Member #: 5702
Cornwall
If the guides are worn then they will give you the smoke. You will be fine if not better without seals on the exhausts particularly on a turbo where the valves get warrm.
