Home > Wanted > Need Pressure Plate in USA
Dr. jinG
Member #: 368
Roseville, CA (USA)
My clutch pressure plate has been deemed un-salvageable by my preferred vendor. However, they do not have any replacements available, and MiniMania wants $100 for a re-manufactured plate. Does anyone have a less expensive supplier for this in the USA, either finished form or good enough for re-surfacing?
1967 Cooper 's' Turbo build @ www.drjing.com
Which colour plate do you need? Greys are not much in the UK and shipping and import duties should cost you that much.
Dark Angel
Member #: 8965
MIldenhall, Suffolk
If you need, I can ship you one from the UK. As long as I can fit it in a USPS flat rate box it should be under $15 to ship. PM me is needed.
Dr. jinG
Member #: 368
Roseville, CA (USA)
Thanks, Dark Angel! Just to be sure that we're talking the same thing, this is what I'm looking for: http://www.minisport.com/mini-spare-parts/info_MS2222.html
MiniSport wants ~40 quid to ship. I'll have it in under a week, but time is not the limiting factor for me.
That's a back plate. pressure plate is the spring bit.
£40 is taking the piss. Get it send to somebody in the UK and forard it on.
