Home > Help Needed / General Tech Chat > Calculating engine air flow with VE etc
almichie
Member #: 2065
Sooooooo, I'm away working in Dublin and i'm bored!
So i thought - i'll do a little reading and try and find a compressor map for a gt1752, that failed. So i moved onto calulating my engines air flow;
So i get 1293cc and i need to convert to CI to use the calulation i found.
1293cc = 79CI (so google tells me)
I'm going to use a 7200RPM limit
So (79x7200)/3456 = 165CFM
Then you need to take into consideration volumetric efficiency. i was guessing 85% but someone assumed 90.
so 165x0.85=140.25CFM
Looking at a compressor map i need to convert this to lb/min so thats divided by 14.27?? = 10lb/min
Or am I going completly mad.
I did find a map on here but with the above figures but it looks VERY close to the surge line and gives me a very low pressure ratio which im not that happy about.
i'm sure im doing something wrong, HELP!!
Shaft seems nice and snug
http://www.not2fast.com/turbo/glossary/turbo_calc.shtml
almichie
Member #: 2065
Brilliant - thanks Colin.
That works a treat! at 18psi with all the other bits programmed in I can expect 194BHP with 142lb/f torque. However the inlet temp will be 52 degrees c
GT1752 is a 50 trim compressor 0.53 A/R. Turbine trim is 70 trim 0.47AR. If that helps any.
but you'll find the GT1752 is on its own
What you need to realise is that the 'RPM' variable is where you would expect peak horsepower, and should be adjusted to suit your cam. You then need to switch the VE number from 75% to 100% to give you an estimated HP range, since finding out the actual VE without some real HP numbers is difficult. The 16v heads are ~90 to 95% VE with the 5 ports ~75 to 80%VE
Also change the AFR value to 12.5:1 and the BSFC to 0.51, since these engines are not exactly the most efficient
That should then give you some reasonable HP figures.
Where did you get that information from Colin?
Use real numbers and work backwards.
Peak HP on a standard Cooper SPi is 63hp at 5700rpm at 75%VE and conservative factory fueling of 13.2:1, while peak torque is 70lbft at 3900rpm at 85%VE.
So, erm, yes, bigger cams, bigger heads and such will give better VE numbers
My 16valver come in at around 90%VE standard head with LT inlet and RS exhaust.
almichie
Member #: 2065
174-236BHP, 128-171Lb/ft With your figures. So the real figures look good, and looking at other members set ups it looks to be the correct figures for my engine. Its got an avonbar billet phase 2 and med FIS head btw.
Where did you find the GT1752 map?
Thanks
Hardly a valid comparison in this situation.
Using real numbers from the NMS RR day in 2009 and Robert's SOT graph shows that the difference in VE between a turbo 5 port and turbo 16v is around 5%.
Granted that if you are camming for a 9k rev limit then the difference would be as you suggest
and remember the 1st cylinder to open supercharges the adjacent cylinder so skewing the ve ...
On 9th Sep, 2011 almichie said:
174-236BHP, 128-171Lb/ft With your figures. So the real figures look good, and looking at other members set ups it looks to be the correct figures for my engine. Its got an avonbar billet phase 2 and med FIS head btw.Thanks
Similar spec to the metro van's engine. 174bhp and 178lb/ft at 17psi allegedly. Still going strong at 25 psi....
I swear I saw the crank sitting on the bench at the Force Racing workshop *tongue* *wink*
That you probably did. Due to our ineptitude of setting up the pre-verto clutch.
It's gear box and a few other bits will be joining it soon....
Sorry to go slightly OT, but are you guys running more than 20psi with the GT17's standard actuator.
yes!
Thought it was a 2056 actuator?
no. gt17 actuator from mikey boy. he has my old gt20 actuator on the tangeringe.
