Home > Non-Mini Discussion > bleeding brakes
wez
Member #: 9271
Stoke on Trent
Ive had to replace almost all the solid brake pipes on my daily run around for its mot, however its parked in the bay outside my house which is on a slight down bank,
so my question is does a car have to be on a flat, level piece of ground for bleeding the brakes?
one day boost will be mine!
On 10th Mar, 2012 Joe C said:
wng691s clubby
Member #: 9252
Cleethorpes
i would say no because as you press the brake peddle down your forcing the liquid out along with the air bubbles. same goes if your using a one man bleed kit the tyre air pressure forces it out
Done now needs redoing lol
Mr Joshua
Member #: 1954
Luton Bedfordshire
If your going to use a one man bleed kit give the peddal a few pumps to help said kit as they do in my experience require some assistance
Own the day
bennyy
Member #: 9037
Doncaster, yorkshire
I would agree with above, gravity should have no effect
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
wez
Member #: 9271
Stoke on Trent
Cheers, im bleeding them the old fashioned way, all though technically it is a one man bleed kit as the wife will be pushing the pedal. Lol
Mr Joshua
Member #: 1954
Luton Bedfordshire
Damn son I hope she dont read over your shoulder
Own the day
