Home > Help Needed / General Tech Chat > head porting and valve compression tool help
Good evening all
a little while back i started mildly porting an ally head, i have only been using the round sandpaper wheels on a dremal and wire wheels to smoothen the finish of the ports, what i am wondering are there any tips that people have for porting and what type of grinding stones to use? What gauges do you use to measure port sizing, how do you make sure you dont hamper the air flow?
Secondly i dont know what type of valve compression tool i will need to get the valves out, wolfie kindly lent me a compresion tool but it doesnt work on the pug head which also is similar to the k head, only works on the mini heads any info would be great.
Lastly i would like to try abit of porting to an aseries head i have as well, what sort of grinding atones should i use??
Cheers paul
i would be very very carefull porting the pug head you have no idea where the gallerys are and you could very easily go into one making the head scrap
Im not doing a massive porting job its more of a clean up and abit of smoothing its on a spair head so not bothered if it messes up, just abit of practice but if it goes well can always flog it on to someone
ive used in the past a cutting burr and the pink grinding stone things for a dremil
i got 5 ports and 3 combustion chambers done before finding a bloody massive crack :(
Mr Joshua
Member #: 1954
Luton Bedfordshire
Re my thread why you should crack check before you start porting! I feel your pain.
Back on topic. I used tungston chip breaker burrs in a pillar drill with the head held in a machine vice port shape was marked from a template and port depth was measured by the drill bed.
Dont forget to dowl your inlet manifold to your head so it all lines up before you start surgery *wink*
Own the day
Advantage
Member #: 1450
Near Paris - France
Hell yeah, always start with the area between the valves on all chambers !
I learned thet the hard way too ...
Rusty by nature
yeah this was way back when i first started, i kept the head still its in my bedroom 8) spent soo much time its worthless in reality but i cant bring my self to bin it
Mr Joshua
Member #: 1954
Luton Bedfordshire
How deep was the crack and was it perchance in number 4
Own the day
