Home > General Chat > top mount turbo
eden7842
Member #: 8852
leicestershire
has anyone done a top mount set up and moved the carb round?
or just moved the carb?
was thinking of ways to get the carb away from my piping hot t3.
I don't think it's really an issue. if you're worried, best thing to do is insulate the turbo and add extra heat protection under the carb.
eden7842
Member #: 8852
leicestershire
does anyone sell a decent heat shield?
jason g on here did some nice ones.
I've seen an inverted t3 before but this was "coupe" using megasquirt.
Look at rober's turbo for good insulation.
I have found that a simple alloy plate around 6" wide under the carb is sufficient.
i use a modified n/a aubment plate, bent between the turboand carb with the spring 'arm' cut off, seems to do the trick
supermotolee
Member #: 2153
kings langley
i have a heat shield going spare its one of jason's with heat reflective tape on it... pm me....
eden7842
Member #: 8852
leicestershire
have we a pic of this shield please?
longy
Member #: 2727
Bicester
I believe Robert a number of years ago did an inverted T3 with a suck through carb
1972 998 TURBO SLEEPER
