Home > Help Needed / General Tech Chat > fuel sender
clubbie70
Member #: 8935
netherlands
Does anyone now how much Ohm the fuel sender unit from a spi/mpi tank is ?
want to use it with a digital speedo
thanks
there's a chap on 16vminiclub that makes little boxes that go between sender and gauge which makes them work together properly. he's called spyda
They go from 0 to 230 Ohms on the later type senders.
clubbie70
Member #: 8935
netherlands
tanks guys, real helpful
The mini sender works in reverse to most modern digital clocks. The box of trickery mentioned above is well worth the extra cash
