Home > Non-Mini Discussion > taking up a big ass hole in the garage slab, tools?
G13B
Member #: 1376
Hi
bought a scissor lift for the cars that i will submerge in the garage floor,
need a 145x90 cm hole it´s a 12 cm slab
do i have to rent a proper saw or can i get away with big ass angle grinder,
chippers, sledgehammer 6-pack of beers?
cheers!
//marcus
Pretty much it, pick up a cheap diamond blade or a big stone cutting blade for the edges, and just keep chipping away at it, sledgehammer won't really touch it, wasted efforts. Maybe best to hire a small concrete breaker for the day.
Fortecphil
Member #: 7641
Jersey, CI
As above, give it a bash by all means but if after a few hours nowt's happening then hire a hilti breaker!!
I'm with fortecphil,
but at 120mm thick a proper slad saw will make easy meat of it, the type used to cut up our roads,lol
carl
On 15th Sep, 2011 fastcarl said:
I'm with fortecphil
It's nice that you are comfortable enough to tell everybody. *wink*
^ you're just jealous.
Phil is pretty, but he's just not my type....
G13B
Member #: 1376
thanks guys,
guess i start out with the stuff i allreday have, the hole dont need to be cute, will make a mould in it to ensure real tight fit lift/floor
ps Carl got the parcel yesterday, they look bad ass8-) many thanks!
Edited by G13B on 15th Sep, 2011.
Fortecphil
Member #: 7641
Jersey, CI
*Rofl!* Bastards. How did the song go again, "I would do anything for some wheels and titanium bits, but i won't do that...."
lol
Edited by Fortecphil on 15th Sep, 2011.
tadge44
Member #: 2500
Buckinghamshire
Still worth starting the cut with an angle grinder IMO.
Dont hire a small concrete breaker get the big Bosch bugger - its hard to handle but boy does it do the job !
got to agree - get the right tool for the job and it will make light work of it
On 15th Sep, 2011 G13B said:
thanks guys,
good news
G13B
Member #: 1376
know there is a hole*wink* used a proper saw
Nice one. Stihl saws are so useful when they're around, use it for everything at work haha, bloody noisy though and drink fuel like there's no tomorrow!
tadge44
Member #: 2500
Buckinghamshire
Neat and tidy - bet you are glad you didn,t go the hammer and chisel route !
G13B
Member #: 1376
yea, this was so much easier, no dust either –just some squirting here and there:)
will tie in a cage and fill up to level with concrete tonight. lift is 18cm folded
Kean
Member #: 341
aka T2clubby
South Staffs
Is it one of those slimline pallet lifters?
I was looking at dropping one in my floor when I poured the concrete but ran out of time.
That lad looks a bit small to be smashing concrete!
G13B
Member #: 1376
not a slimline, i guess you mean the 9cm thick ones with remote pump/reservoar and 2 slim cylinders?
mine has everything under the table,
lifts 1.000 kg, 85x135 cm table, pinch protection, got it for £400
lads are small, but strong*wink*
G13B
Member #: 1376
the saga continues,
17 bags of concrete
sunked in the hole, just the sides to do now
+ slit for cables then it´s lifting time*wink*
G13B
Member #: 1376
the plot thickens, just a small skim in top left
pic of cables before i ripped them out, not much for electrics*wink*
Bloody hell, your garage must be nice and toasty given the amount of insulation in the floor!
G13B
Member #: 1376
yea it´s almost too warm for hard work,
can´t get it under 18-19C due to the air to air heater not going lower, tried running it in intervalls last winter, but then the outside unit froze solid (condens)
– guess i have to live with it, ha ha
G13B
Member #: 1376
lifting time*wink*
flash fucker! *wink*
G13B
Member #: 1376
he he, bye bye axle stands - this is the new shit*wink*
