| Home > Help Needed / General Tech Chat > intermittent mpi starting issues - starting to become a big problem. | |||||||
16th Sep, 2011 at 01:50:31pm
Hi, I have been having an intermittent starting problem with my mpi Cooper. I was wondering if anyone has any expereience of this problem and what the cause may be? Firstly, it’s a pain due to the intermittent nature – the engine will crank but not fire up
16th Sep, 2011 at 02:51:30pm
just had it plugged in, there were faults on nearly everything where we have had the engine in and out over the last few years. he reset it, if the problem persists it will hopefully show when i take it back. i have a feeling it wont be as straight forward as this... |
857 Posts Member #: 1778 Post Whore Northants |
16th Sep, 2011 at 03:00:18pm
Not ever had a play with an mpi (well technically...) but id also check your coolant temp sensor |
![]() 514 Posts Member #: 2104 Post Whore Essex - UK |
16th Sep, 2011 at 07:41:15pm
Could be a failing coil pack might be worth swapping if you have a spair or no some one with one could still produce a spark but e weak. My old v twin bike had a dud coil pack but still worked to a just was temperamental and hard to start "Tuning should be a compromise between what is possible and what is necessary"
16th Sep, 2011 at 08:08:27pm
On 16th Sep, 2011 welshdan said:
just had it plugged in, there were faults on nearly everything where we have had the engine in and out over the last few years. he reset it, if the problem persists it will hopefully show when i take it back. i have a feeling it wont be as straight forward as this... Altough i'm not familiar with MEMS, surely if a whole load of fault codes were reported, it would be worth checking them all out first even if you have subsequently reset the ECU. The codes don't get reported for no reason (well not normally anyway). Why wait for the same code to re-appear before you look at it ??? Schrödinger's cat - so which one am I ??? |
16th Sep, 2011 at 08:26:06pm
thanks for the input. basically the guy said there were too many faults to look at, and asked if i had been unplugging sensors - i did this when changing the engine. said reset it and see what i have got. i think two came back up straight away, oil temp and ambient air or something, which he said were nothing to worry about. i think that the best thing to do is see how it goes and let him plug it back in when the fault occurs again. hopefully this way it will narrow things down a little. i think that the codes shown were in relation to the different sensors and componets being unplugged during engine removal/fitting.
16th Sep, 2011 at 09:15:26pm
Have you looked at all the vacuum lines?
16th Sep, 2011 at 09:16:06pm
I don't know how the mpi ecu works but from experience temp sensors are pretty important when it comes to starting a fuel injected car. Reading too cold and you could be injecting too much fuel and flooding it, or opposite, too hot and not enough fuel to fire. |
28th Sep, 2011 at 10:47:35pm
Thanks for the input. I decided to have the errors wiped from the Ecu and start again. This was around two weeks ago and all has been good since.
28th Sep, 2011 at 11:13:21pm
an 82 thermostat won't fix an overheat.
30th Sep, 2011 at 10:11:44pm
Cheers for the input sprocket. With both of these problems it s case of elimination. At the moment the overheating is my priority. Tomorrow I will compression test it, change the thermostat and change the header tank cap. As far as I understand a non sealing cap and/or faulty thermostat could contribute heavily to the overheating. I will reduce the fuel pressure when changing the thermostat for the 82.
11th Oct, 2011 at 11:49:44am
thanks for the input on this. i changed a few parts a few weekas ago and things have improved with the car.
