| Home > Help Needed / General Tech Chat > Electrical / Fuel Issue | |||||||
134 Posts Member #: 9579 Advanced Member Tadley, North Hampshire |
17th Sep, 2011 at 11:04:53pm
Mini is currently off the road at the moment with a pretty terminal fuel / electrical problem. Here's what happened. I'd just returned from a rolling road tune at Slark Engineering (see my other threads) so the car had been put through its paces.
My build thread: http://www.turbominis.co.uk/forums/index.php?p=vt&tid=440970 |
17th Sep, 2011 at 11:07:12pm
17th Sep, 2011 at 11:16:46pm
I suspect not, but it soon will be!
On 17th Sep, 2011 Joe C said:
sounds like no 2 to me, is the pump fused? My build thread: http://www.turbominis.co.uk/forums/index.php?p=vt&tid=440970 |
18th Sep, 2011 at 12:16:48am
On 17th Sep, 2011 daveg79 said:
Mini is currently off the road at the moment with a pretty terminal fuel / electrical problem. Here's what happened. I'd just returned from a rolling road tune at Slark Engineering (see my other threads) so the car had been put through its paces. Cabin began to fill with smoke from melting electrical wire. Washer pump then cut in and I pulled over. Found wire to fuel inertia switch on one side was melted. Disconnected the washer pump, and bypassed the (then suspect) inertia switch to get home. Found rest of wire back to fuel pump (SPI tank) also started to warm up and melt, cue more smoke and trip home on a trailer. When the ignition is on, the fuel pump is audibly intermittent. Battery is now disconnected until I can figure out the problem. So I'm suspecting one of the following: 1) heat from turbo during tuning has meted some cabling, causing a short circuit somewhere between the washer pump and the fuel pump 2) Fuel pump is faulty and drawing too much current. I obviously need to strip back to find out exactly whats melted and needs replacing, but I'm really looking for some other opinion as to what might have gone wrong so I can solve the root cause. Just bought the car and desperate to get it on the road for the Castle Coombe meet on the 24th... Neither make any sense. Why on earth would any wiring be anywhere near the turbocharger to melt in the first place ? And obviously the fuse for the fuel pump would protect that wiring from any such damage. And Ive never seen an efi pump go faulty and overload wiring. They usually just stop working. 9.85 @ 145mph
18th Sep, 2011 at 09:26:27am
Well if the wire is melting all the way to the fuel pump the issues must be at or near the pump.
http://www.twin-turbo.co.uk
18th Sep, 2011 at 01:09:47pm
Is it the SPi pump in the tank? How much boost where you running? You may have over worked the pump as they don't flow enough fuel for lots of boost. On 11th Feb, 2015 robert said:
18th Sep, 2011 at 10:08:12pm
Okay, so by way of an update. Traced the loom back today. The wire from the interia switch to the relay is totally fried, with the damage less severe towards the relay end. Damage to the rest of the loom is minimal, and there is no damage between the relay and the fuel pump.
18th Sep, 2011 at 10:32:55pm
ignore the relay rating, its just a current rating like a wire, it wont make the current it jsut means it wont fail as easily.
18th Sep, 2011 at 10:57:22pm
An intermittent short on the 12v wire to the fuel pump to ground would cause the pump to be intermittent and could cause the wire to melt if the fuse rating is incorrect. If the washer motor wire is in the same loom it also may be missing some insulation somewhere and shorting to the fuel pump supply causing it to run. (long shot..) Basically you need to have a good look around and poke about with a meter. If the wiring is bad enough for shorts like that then it needs a proper looking at.
19th Sep, 2011 at 07:49:30am
hmmm wire to pump shorting on a hole or clip on the floor ? Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
19th Sep, 2011 at 10:07:07am
SO clearly there was no fuse protection ? 9.85 @ 145mph
19th Sep, 2011 at 08:31:39pm
Fuel pump is good, drawing 2.8A. Reckon a faulty relay leaking current into the relay switching line or a dodgy cable. Either way, they're both going to be replaced.... My build thread: http://www.turbominis.co.uk/forums/index.php?p=vt&tid=440970 |
19th Sep, 2011 at 08:35:31pm
19th Sep, 2011 at 08:54:22pm
On 19th Sep, 2011 Joe C said:
and add a fuse before you end up with XL5! Agreed! My build thread: http://www.turbominis.co.uk/forums/index.php?p=vt&tid=440970 |
20th Sep, 2011 at 09:26:35pm
Okay. These things are never simple. I've put all the wiring in the loom. Tested the continuity all the way along, connected everything up and fuel pump was working perfectly with the ignition on. BUT.... turned the key to start the engine then click and nothing. Now I've lost all power. I'm guessing another short somewhere, but goodness knows where to start. Any suggestions!?!
Edited by daveg79 on 20th Sep, 2011. My build thread: http://www.turbominis.co.uk/forums/index.php?p=vt&tid=440970 |
20th Sep, 2011 at 11:30:49pm
Dug around a bit more....
20th Sep, 2011 at 11:46:08pm
Go for simple stuff first.
In the 13's at last!.. Just |
