Home > Help Needed / General Tech Chat > clutch opinions please
c2_mad
Member #: 4215
hi guys..
i have come to the stage of fitting my clutch to my rebuilt engine, i went for a grey diaphragm and ap racing clutch. i have been reading up on here about getting the spring as flat as possible so was going to take the lugs from the back plate down from the standard 25.4mm to 23.5mm as suggested by turbophil on his site. but i went and measured it, my lugs are already 23mm so the previous owner must have already done this.
so fitted everything up and this is how it sits
http://s20.photobucket.com/albums/b217/Car...nt=SDC12025.jpg
its not 100% flat but i think pretty dam close, opinions?
also i noticed these marks on the back plate, i cant feel anything when i run my finger over them, will this back plate go again as is?
here is one of the flywheel which seems fine.
any advice/coments greatly apreciated.
thanks in advance*wink*
c2_mad
Member #: 4215
another quick question, do i have to have the crank in a specific postion before i put on the clutch assemlbly?
obviously i have to be able to put the keyed washer in, put do i need to have the piston at tdc or something?
bennyy
Member #: 9037
Doncaster, yorkshire
put the crank at what position you like, the clutch assembly can only go on one way.
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
wng691s clubby
Member #: 9252
Cleethorpes
have you got the diaphram lined up correctly to all the A's?
Done now needs redoing lol
c2_mad
Member #: 4215
yeah mate.. all lined up*wink* i didnt see an a on the diagphram tho, pretty sure i saw it the first time i looked at it, now i cant find it. any clue in the position its usually in? was just wondering if the crank position matered.
will get it all tightend up*wink*
thanks for the help guys*wink*
Edited by c2_mad on 21st Sep, 2011.
