Home > Wanted > 20832A Piston
longy
Member #: 2727
Bicester
Hey guys,
im after just one AE 20832A piston, will be at combe on saturday.
Cheers Chris
1972 998 TURBO SLEEPER
chris ,are there any other numbers that are the same as this piston ?
these are the only pistons other then the 20831 pistons with holes rather then slots from an a+ engine i have seen, others may have other experiences.
Thtas a standard MG Metro piston. The 20831 is the standard MG Metro Turbo piston.
Both look the same but the turbo piston has a larger dish.
Good luck finding a decent one, I scrapped a full set of both
chris if you want to pop in on the way back from combe and have a look at this allegro piston , it looks pretty strong ,and only has a tiny 1cm slot in it .and its 12cc .
longy
Member #: 2727
Bicester
cheers robert,
i thought a that might be the case, ive found it hard enough finding piston rings let alone another piston.
