| Home > Help Needed / General Tech Chat > Idle - Trouble Shooting | |||||||
![]() 2054 Posts Member #: 452 Post Whore Chester, UK |
23rd Sep, 2011 at 03:40:27pm
Hi All
Edited by t@z on 23rd Sep, 2011. |
23rd Sep, 2011 at 03:42:49pm
easy way to check for air leaks is by spraying carb cleaner at wherever it could be leaking, usually manifold gasket. Edited by Nick on 23rd Sep, 2011. On 20th Oct, 2015 Tom Fenton said:
23rd Sep, 2011 at 07:26:23pm
well i got it idling ish, tighten'd up the manifold studs, re sealed the bit your meant to block off as it wasnt as sealed as it could be and also checked the vacum hose and i think its ok......its sold as a vacum hose so should be up to the job.
23rd Sep, 2011 at 08:45:14pm
On 23rd Sep, 2011 Nick said:
easy way to check for air leaks is by spraying carb cleaner at wherever it could be leaking, usually manifold gasket. Or volvic water, radox shower gel Just ask Robert.
23rd Sep, 2011 at 08:46:44pm
That only works if you have a stray duck in your engine bay. On 11th Feb, 2015 robert said:
