Home > Help Needed / General Tech Chat > 998 breathing heavily
Nick
Member #: 154
Midlands
Having a bit of a head scratcher at the minute, looking at a std thou non turbo that's chucking out half a litre of oil from the tappet breather in 5 miles or so of motorway driving speeds. Comp test is 160 across all 4, and goes up by 5psi on a wet test, runs like a dream, no smoke, breather can is clear, filler cap breather is clear, no crankcase pressure at idle or at high revs on the drive. Any ideas?
wng691s clubby
Member #: 9252
Cleethorpes
when mine did this which was also a none turbo 998 but i had lost pressure on number one i had disintegrated a piston.
Done now needs redoing lol
only from the tappet breather and the other breathers are ok? could be some crap sitting in the tappet chest drain holes making the tappet chest fill with oil.
Nick
Member #: 154
Midlands
There's only the one breather on a std 998.
I did wonder if the tappet chest was filling up but surely it'd do it at sustained revs on the drive?
blocked breather in the oil cap?
maybe the head is lifting slightly when under load?
i have done a head gasket in the past but the compression test came out ok it ran like shit though
Nick
Member #: 154
Midlands
Just fitted a brand new cap, trying without one atm :s
Plumbed the breather back into the carb and after 30 seconds at 60mph massive plume of blue out the exhaust.
It's your old engine brett, lol :)
you said its from the tappet chest ....if so, my monies on a cracked ring land on one piston or more,
sorry if its bad news ..........make sure you have exausted all other tests
