| Home > Help Needed / General Tech Chat > Aluminium Alloy Duplex | |||||||
26th Sep, 2011 at 12:09:01pm
Anyone had any long term experience with aluminium alloy cam sprockets on a road engine?
26th Sep, 2011 at 01:08:24pm
Which one you looking at MED/Piper or Swifty?
I seriously doubt it! |
26th Sep, 2011 at 01:29:03pm
I have the MED one in the Mig and am thinking about fitting one in the new 998Ti.
26th Sep, 2011 at 02:17:14pm
You could use a magnet in a steel sprocket. Probably not as easy as a bolt in an aluminium one but still not too bad.
26th Sep, 2011 at 02:46:46pm
I have no experience of alloy in chain sprockets but, there are certain grades of aluminium alloy that are made to work harden very quickly. Those grades will stand a lot of abuse from steel (especially if lubricated).
Edited by Rod S on 26th Sep, 2011. Schrödinger's cat - so which one am I ??? |
26th Sep, 2011 at 03:29:22pm
The Swiftune one is 7075 which is a very high grade suitable for gears and sprockets etc.
Edited by Paul S on 26th Sep, 2011. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
26th Sep, 2011 at 10:09:22pm
Well if these were wearing badly with high use, then someone on here would have heard.
27th Sep, 2011 at 07:01:42am
Id say if they do a season of Miglia without wearing then they can do 10 years on the road without wearing.
Edited by paul wiginton on 27th Sep, 2011. I seriously doubt it! |
27th Sep, 2011 at 09:29:25am
I'd hope it would be hard anodised, and if its not, get it done! That stuff generates sparks when you machine it!!
27th Sep, 2011 at 10:15:41am
With respect Colin, would not the layer of aluminium oxide rip the chain to pieces in no time :) Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
27th Sep, 2011 at 10:31:51am
On 27th Sep, 2011 Paul S said:
With respect Colin, would not the layer of aluminium oxide rip the chain to pieces in no time :) I don't understand
27th Sep, 2011 at 10:40:10am
Looking at the datasheet for 7075, in it's normal heat treated form, Brinell hardness is ~150.
27th Sep, 2011 at 11:10:52am
With respect Colin, would not the layer of aluminium oxide rip the chain to pieces in no time :) I don't understand ![]() As anodising cretes a surface of aluminium oxode, a very abrasive substance, I thought there may be wear issues. However, it appears a hard anodised surface has good bearing qualities
27th Sep, 2011 at 11:47:17am
Sand is an abrasive substance, but they make microchips from it
