| Home > Technical Chat > Trigger Wheels | |||||||
238 Posts Member #: 1649 Senior Member West Sussex - dreaming of forced induction! |
27th Sep, 2011 at 08:03:44am
Whats the best one to use with a megajolt system???
27th Sep, 2011 at 08:14:43am
Personally I would be going for the Tom Fenton™ machined crank damper and matching sensor bracket.
27th Sep, 2011 at 09:11:51am
I have the med trigger wheel and bracket, spot on and looks the dogs... Audi s4 b5 - 470bhp & 486ft lbs
On 15th Mar, 2012 wil_h said:
![]() 538 Posts Member #: 9393 Use the search function before buying stuff from me... stoke on trent |
27th Sep, 2011 at 01:20:28pm
How much are the Tom Fenton ones? I'm after one too |
27th Sep, 2011 at 01:23:31pm
there's a post in the For Sale section with details On 11th Feb, 2015 robert said:
27th Sep, 2011 at 01:32:26pm
*rushes off to the forsale section* |
27th Sep, 2011 at 01:53:25pm
When I was in the market for one tom was in the middle of getting the tooling to do his own on his mill, there was about 2weeks wait, he may have sorted it now? Audi s4 b5 - 470bhp & 486ft lbs
27th Sep, 2011 at 03:58:23pm
I had a kad set up and it was a piss about to work with, now i have a tom wheel i have not looked back. Its a top bit of work. I have started posting on Instagram also my name on there is turbomk1golf
![]() 2057 Posts Member #: 9252 Post Whore Cleethorpes |
27th Sep, 2011 at 05:18:12pm
i also have recently purchased the med trigger wheel kit and its a great bit of kit and as bennyy said it does look good Edited by wng691s clubby on 27th Sep, 2011. Done now needs redoing lol |
63 Posts Member #: 290 Advanced Member Basingstoke, Hampshire |
5th Oct, 2011 at 01:40:55pm
I am also after a trigger wheel/pulley as the machine shop doing my engine has just requested one to use when balancing the crank.
Will my project ever be finished !!? hopefully you guys can help !
12th Oct, 2011 at 01:33:13pm
Guy at the machine shop said he gets discount at med so have gone for their pulley but will make up my own sensor bracket to save some money.
12th Oct, 2011 at 02:32:45pm
I I havnt balanced my med pulley, I was told by a few that its such a small amount it would not matter. Audi s4 b5 - 470bhp & 486ft lbs
![]() 825 Posts Member #: 9661 Post Whore Sheffield South Yorkshire GB. |
9th Nov, 2011 at 11:47:56pm
I bought my megajolt kit from trigger wheels.com, just had to alter the senser bracket. Everything in there to do the job for around 330 pounds Main Build
10th Nov, 2011 at 08:33:35am
If you go for a machined standard "A+" damper pulley, buy a new one first. Second hand ones are three out of four times rubbish.
Edited by Vegard on 10th Nov, 2011. On 13th Jul, 2012 Ben H said:
10th Nov, 2011 at 10:23:25am
I use the specialist components trigger wheel, but with ford sensor. failing that I'd use the med damper kit. On 7th Oct, 2010 5haneJ said:
