| Home > Help Needed / General Tech Chat > Trouble retrieving MJ Map - Anyone in bristol area? | |||||||
![]() 568 Posts Member #: 1200 Post Whore Bristol |
28th Sep, 2011 at 10:37:21am
Hi all
95 Posts Member #: 9314 Advanced Member Chippenham, Wilts |
28th Sep, 2011 at 11:00:26am
If you over my way, you can borrow a laptop with a serial port and megasquirt cable, or arrange to get it collected Edited by Ratty on 28th Sep, 2011. |
28th Sep, 2011 at 11:31:28am
Alright mate, i could drive it over but the MOT ran out on friday, I could always get al to pop over with it and then drop it back to you the same day? let me make some calls Edited by pickmeup on 28th Sep, 2011. |
3rd Oct, 2011 at 01:18:43pm
im now onto my 3rd usb-serial cable, i think the cable is fine as its showing up in the computer, ive set the port speeds to what it states on the magajolt website but im still getting the timed out reading cylinder count? any ideas?
3rd Oct, 2011 at 01:25:59pm
do the com ports in yourr device for the USB to serial adaptor are set the same in the Megajolt software.
3rd Oct, 2011 at 10:15:43pm
yeah im changing the MJ software COM port to match the USB-Serial lead ive got plugged in, the MJ must be working as the car starts and runs fine? |
4th Oct, 2011 at 09:28:04am
The ONLY serial cable I could get to work was from Maplin. I have 2 now.
5th Oct, 2011 at 09:41:31pm
that would be good mate, it could be the firmware as i bought a cable from maplins at the weekend and it didnt work? give us a shout when you are on the move |
5th Oct, 2011 at 10:02:14pm
I downloaded to drivers from the net from the manufacturers website. On 7th Nov, 2011 apbellamy said:
5th Oct, 2011 at 11:09:00pm
On 4th Oct, 2011 almichie said:
The ONLY serial cable I could get to work was from Maplin. I have 2 now. They're not expensive. I assume it's the drivers that are good, not the actual cable. Your welcome to borrow one, but you'd be better off buying one seeing you have megajolt in the car... I can come down one evening - to run in the new engine of course, with the netbook and see what we can do?? mate ive had 5, including 1 pcmcia card to serial, only the maplins one worked and it works flawlessly Yes i moved to the darkside |
5th Oct, 2011 at 11:11:53pm
On 28th Sep, 2011 pickmeup said:
Hi all im having issues trying to get my laptop to retrieve the map from the british open classic, i struggled for a day trying to get the USB-serial convertor to work and finally sorted out the COM POrt for it. When i load up the megajolt software it finds the port but it still has trouble connecting to the unit , i get the timed out error code. Is there anyone in the bristol area that could come down with there laptop and cable to help me retrieve the map and check that its all working ok, the car runs fine but I just want to have the map and to make sure the MJ is all good. Cheers Gaz its not the connector inside the mjlj unit is it? the one i had, had a break some where in the circuit board and i had to solder jumper wires onto the board Yes i moved to the darkside |
6th Oct, 2011 at 01:33:05pm
thats the next plan of attack after i get al to try his cable and laptop, is get the mjlj apart and check the connections. the cars coming off the road soon anyhow but it would be nice to have the map to check it over. |
