| Home > Help Needed / General Tech Chat > Cylinder head welding in north Wiltshire or bristol | |||||||
28th Sep, 2011 at 06:02:36pm
After my misfire at the weekend it seems the head gasket failure took more than the gasket.
28th Sep, 2011 at 08:26:51pm
Webb welding chiseldon nr swindon very very good welder Crystal Sound Audio said:
28th Sep, 2011 at 09:04:06pm
Christ almighty. Ive done that on Aluminium before, but never cast iron !!!
29th Sep, 2011 at 07:53:37am
It could have been, tbh I had lost a little water on my way to the track so that could have been the start of the gasket failure (read it defiantly was) but as I have a new engine in my garage i thought I might as well have some fun! On the 5th lap coming on to the home straight I changed from third to forth flat out and it was the misfire from hell!!! The engine was warm at the time as well... The engine block is the same as above, I'll put it down to experience.
29th Sep, 2011 at 07:54:22am
95 Posts Member #: 9314 Advanced Member Chippenham, Wilts |
29th Sep, 2011 at 08:56:20am
If you have it welded it will more likely start to crack next to the weld due to the different expansion rates of the materials.
29th Sep, 2011 at 11:30:40am
Is there enough cc's / enough meat left below the damage to skim it and sell as a N/A head? You could then use the cash to help fund a TurboPhil / Benross jobbie?
In the 13's at last!.. Just |
29th Sep, 2011 at 01:45:12pm
Hmmm that's a pain John. I'll measure it tonight and see if it can be skimmed...
30th Sep, 2011 at 09:23:42am
Measure the thickness of the base around the oil and waterways as there may not be enough metal to skim the head.
30th Sep, 2011 at 05:40:17pm
Sorry! But that head is goosed SCRAP! the block also if it has that amount of gouge in maybe some one can use the block for a short motor build ? ............ you say .... It runs mega jolt so timing shouldn't have been the cause,
