Home > Help Needed / General Tech Chat > want my engine to be BLINGED OUT!!!!
b16_b
Member #: 429
newcastle upon tyne
anyone recommend an engine rebuilder or can rebuild my engine and carb etc...and clean it up with fresh lick of paint etc...
any info would help...need to impress the lass with my nice engine!!!!lol
totty magnet*wink*
*BEFORE ANY ONE SAYS CHARVA ETC...I DONT SEE THE POINT OF SPENDING A FORTUNE ON THE OUTSIDE AND INTERIOR THEN PUTTING A ENGINE IN WHICH HAS BEEN SITTING AROUND IN GARDEN GETTING DIRTY AND RUSTY ETC....*
minimark
Member #: 19
newcastle
i`ve heard bob is good at building
minimark
Member #: 19
newcastle
think he`s located in bobsville
minimark
Member #: 19
newcastle
sure he got a web site somewhere.....
www.bobthebuilder.com?
minimark
Member #: 19
newcastle
thanks ....
Or why not save yourself a bit of cash, get the mechanics rebuilt if you are not to confident, and then do the elbow grease jobs yourself? Much more satisfying when its in to know that "I did that".
minimark
Member #: 19
newcastle
i was looking under bob the bodger
minimark
Member #: 19
newcastle
AF racing do full "race" spec engines
b16_b
Member #: 429
newcastle upon tyne
this engine shit doing ma head in mark...iam not rebuilding it! il fcuk it all up...
wish i had of spotted that 2k engine iain got from orspeed...
I JUST WANT MY MINI DONE AND A NICE LOOKING CAR WITH A NICE BUNCH OF BANNANA'S(BHP, BEFORE I GET A SHITTY COMMENT) SO I CAN GO OUT AND HAVE A LAUGH WITH OTHER MINI OWNERS.
b16_b
Member #: 429
newcastle upon tyne
fcuk off mark...lol
minimark
Member #: 19
newcastle
think you slipped and pushed the caps lock key
Plenty of places that will rebuild it for you, take your engine and 2k to Morspeed or similar and I'm sure it will come back all nice and spanky.
Oh and turn the Caps Lock off, you'll find it
<------over there
minimark
Member #: 19
newcastle
want you car painted or NOT .lol
Blackmail will get you everywhere.......
b16_b
Member #: 429
newcastle upon tyne
i put the caps lock on as its the point iam trying to get across!!!
mark get prepping car got carbon coming your way soon want that mini done!!!! lol
yeah may be a 2k engine ive bought but ive still got loads of bits to fit and buy! It doesnt stop there!!
Plus its hardly a "cruising motor"....
just stick with a std rebuild if thats what you want to do to it?
*smiley*
b16_b
Member #: 429
newcastle upon tyne
cheers iain but i want a fast engine that looks good*smiley* il make the thing cruise!(BEST OF BOTH WORLDS)
iam a pimp at night!*wink*
i just want it running and looking nice...not bothered if it blows up through heavy driving etc.......thats life!*smiley*
minimark
Member #: 19
newcastle
cars all prepped mate
Here you go then
293-1310cc TURBO BOOSTER ENGINE
The block is chemically cleaned, Drilled and tapped for 11-stud fixing and Machined for a steel center main Strap, Bored and honed to a finish size of +020 or +040, Re-surfaced to ensure a perfect head gasket seal, Then fitted with new cam bearings. All threads are checked and re-tapped then after a final clean the block is painted and fitted with new oilways & core plugs.
Crankshaft is re-ground, Balanced, Hardened, and supplied with new VP2 bearings.
Con-rods are checked for size, Complete with new ARP bolts and nuts, Balanced, Then a set of Omega 10cc LOW compression pistons are fitted.
A performance MSPD T2 camshaft, followers, High flow TURBO oil pump and Steel duplex timing gears complete the engine and it is then assembled including a timing cover and damper.
The gearbox is one of our fully re-built units which is fitted to the engine along with new idler shims and primary shims. *Lightened flywheel and back plate is used with a performance plate and Up-rated cover, Then balanced.
Cylinder head is one of our turbo booster units, Then supplied with a 1.5 Roller tip rocker assembly, And Fitted with a new gasket, including all tappet adjustments set.
Fully assembled 1293 -1310cc Turbo booster engine £2100.00 exch
Buy one of those then. Its not just special engines that iain found that are for sale.
minimark
Member #: 19
newcastle
nearly finished
minimark
Member #: 19
newcastle
looking good mate , loadsa bling
b16_b
Member #: 429
newcastle upon tyne
lol mark...
cheers tom..been looking into the package ready built engines...that spec means nothing to me...all i care about is the 0-60 time the bhp at the wheels and that the thing stays together for at least a few month of cruising and racing abit...
www.morspeed.co.uk
Only took me an educated guess at a website address and a few clicks to find that.
I am sure Avonbar, MED et al all do similar packages.
minimark
Member #: 19
newcastle
2 grand mota lasts 2 months .......
thats 12k a year ............nice
Disk full (/tmp/#sql_c9d4b_0.MAI); waiting for someone to free some space... (errno: 28 "No space left on device")
