Home > Help Needed / General Tech Chat > fuel tank
mr t bo
Member #: 78
milton keynes
hi all
dont know if anyone can help? i have been given a fuel cell by a mate. the cell has the outlet pipe at the top of the tank so the fuel has to be sucked up to the top of the tank before it reaches the pump. would this be ok using the standard m/t fuel pump or would i have to plumb another pump in? any advise? was not sure as the mini tank has the outlet at the bottom.......
thanks jonny
nogin
Member #: 487
westbury, wiltshire
its all good mine is sucked from the top and works ok
"Can I legally marry people now that I am ordained in the Church of the SubGenius?" aka i know jack sh"t
i also make things
i love coming home to chrome
turbo pumps usually need to be gravity fed to work effectively.
think you'd really need to use a lift pump to a swirl pot or something.
Dangerous
Member #: 417
If the pump is lower than the tank once the pump has filled then surly it will be syphoning it out so therefore under gravity anyhow
Doodmeister
Member #: 149
Alberta, Canada
I would say you’d be fine running it from the top of the tank.
Most fuel pumps have a small amount of lift; I know the Bosch EFI pumps can lift around a meter before running into trouble with cavitation.
Give it a go and report back your finding.
mr t bo
Member #: 78
milton keynes
will do should be putting the tank in shortly will let you know how i get on
Disk full (/tmp/#sql_c9d4b_0.MAI); waiting for someone to free some space... (errno: 28 "No space left on device")
