| Home > Help Needed / General Tech Chat > Payen BK450 bad batches still about? | |||||||
54 Posts Member #: 9621 Advanced Member Scotland |
30th Sep, 2011 at 07:43:48pm
Hiya,
2nd Oct, 2011 at 12:21:54pm
id guess yours wouldn't have been sat on the shelf for nearly 2 years 13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
2nd Oct, 2011 at 01:25:24pm
I believe theres a post with batch numbers or dates to look out for. I'll have a look.......
Edited by Jason G on 2nd Oct, 2011. On 19th Jan, 2010 wil_h said:
11th Oct, 2011 at 03:58:33pm
Struggling to find any dodgy batch codes for them as i have just obtained one from minispares. Surely this issue is resolved now as it was over 2 years ago but be nice to know for peace of mind!! -MINI CLUBMAN 1380 TURBO- |
11th Oct, 2011 at 04:38:30pm
i thought it was place of manufacture related , eg since then ive only buy Payen uk bk450's Yes i moved to the darkside |
11th Oct, 2011 at 07:26:58pm
It was down to the bad fire ring metal batch I think I heard... On 7th Nov, 2011 apbellamy said:
461 Posts Member #: 9229 Senior Member newcastle upon tyne |
11th Oct, 2011 at 08:31:46pm
ive just took mine of as doing a rebuild wasnt happy with the fire rings after removed no engine problems but didnt look right between the bores & had a look at the packet its from belgium also seemed to leave a kind of silicon resedue once removed which ive never seen before not sure if anyone else has noticed this? |
11th Oct, 2011 at 10:54:12pm
Bugger, mine has belgium on the packaging too -MINI CLUBMAN 1380 TURBO- |
12th Oct, 2011 at 08:19:18am
i got the chap at my local machine shop to call the payen rep.he was told all gaskets are made abroad ,and none are made in uk . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
13th Oct, 2011 at 06:45:19pm
Interesting that they are all made abroad, so they must of sorted it then if were all getting the same ones otherwise everyones would be failing....
13th Oct, 2011 at 06:48:30pm
The one I used this year wasn't a uk one and I've had no problems! |
13th Oct, 2011 at 06:51:26pm
I've got 2, the one in my engine defiantly said made in England. The other is a kit with on in and that says made in belgum bun On 7th Nov, 2011 apbellamy said:
13th Oct, 2011 at 06:59:27pm
If they moved the manufacturing equipment to Belgium, ie, specifically the dies that do the final pressing, the HG itself could still say GB no matter where it was made.
13th Oct, 2011 at 07:32:41pm
The DK451 set I've just bought has 'made in belgium' printed on it.
In the 13's at last!.. Just |
13th Oct, 2011 at 08:22:56pm
i have one on the shelf and it 100% 'Says' made in england its new was from minispeed this year Yes i moved to the darkside |
