| Home > Help Needed / General Tech Chat > t2/t3 turbo? | |||||||
2nd Oct, 2011 at 12:20:41pm
hi all
13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
2nd Oct, 2011 at 12:28:35pm
mismatching turbo bits is often a PITA,
2nd Oct, 2011 at 07:17:19pm
ok scrap that plan straight away,
2nd Oct, 2011 at 07:20:39pm
thats not a bad idea, On 28th Aug, 2011 Kean said:
2nd Oct, 2011 at 07:22:43pm
GT20 would also be a good bet if you are looking for 200+ If something is worth doing, it's worth doing half of. |
2nd Oct, 2011 at 07:27:30pm
2nd Oct, 2011 at 07:30:11pm
well im after somthing that will spool up quick and keep on going and going.
2nd Oct, 2011 at 07:33:43pm
probably better off with the 17 or the td04 then, i think the 20 will spool up fairly late, On 28th Aug, 2011 Kean said:
2nd Oct, 2011 at 07:40:59pm
gunna ask about and see what i can come up with for cheap.
2nd Oct, 2011 at 07:43:33pm
IIRC the TDo4 off the std imprezza is a good bet, not the WRX or STI ones, there probably some info on here about it, also I think a TD04 was used on some of the saabs instead of the 17 On 28th Aug, 2011 Kean said:
2nd Oct, 2011 at 07:48:04pm
i take it there not water cooled?
2nd Oct, 2011 at 07:48:21pm
You can slot the flange on the GT17 so that it fits the metro manifold. You can also cut and shut a 9-3/9-5 downpipe to suit. If something is worth doing, it's worth doing half of. |
2nd Oct, 2011 at 07:55:12pm
humm defo a plus point 13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
