| Home > General Chat > Valve size | |||||||
![]() 399 Posts Member #: 793 Senior Member Milton Keynes |
3rd Oct, 2011 at 04:22:34pm
Now when speaking in terms of valves for all out power in a N/A format, the bigger the better aswell as quantity ie:16V.
3rd Oct, 2011 at 04:25:30pm
Obviously the same applies. Bigges holes equals more power. The thing with turbocharging, is that there are several other ways to the same goal. On 13th Jul, 2012 Ben H said:
3rd Oct, 2011 at 04:48:50pm
as above really,
3rd Oct, 2011 at 04:52:04pm
Would I be right in thinking that the valve area on a 16v head is far greater standard size, than the largest sized 5 port valves you could fit? https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
3rd Oct, 2011 at 05:24:17pm
On 3rd Oct, 2011 matty said:
Would I be right in thinking that the valve area on a 16v head is far greater standard size, than the largest sized 5 port valves you could fit? Indeed. On 13th Jul, 2012 Ben H said:
3rd Oct, 2011 at 06:13:29pm
Would I be right in thinking that the valve area on a 16v head is far greater standard size, than the largest sized 5 port valves you could fit? Indeed. no. 36mm mini inlet 907.5mm2 27mm kad inlet 981.25mm2 37.59mm mini inlet 994.33 mm2 30.4mm kad inlet 1266mm2 so apart from the race ,not much in it . Edited by robert on 3rd Oct, 2011. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
3rd Oct, 2011 at 06:37:07pm
What if you add lift to the equation and get valve CURTAIN area? On 13th Jul, 2012 Ben H said:
3rd Oct, 2011 at 06:44:23pm
then you throw cams into the equation... what lift, how fast etc. On 28th Aug, 2011 Kean said:
3rd Oct, 2011 at 07:30:47pm
I thought that throat area less stem area is the critical dimension. Where the velocity is the highest. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
