Home > For Sale > Ultralight pre verto clutch
Minispares ultralight flywheel, standard back plate with 1.5mm off the lugs and the back turned down by Force Racing, double grey cover, all bolts, spacers, straps (3 straps per lug) etc etc. I'll try and dig out a standard friction plate to go with it if you need one. All have been balanced together so are good to go straight on. Pre-engaged (remote solenoid starter) ring gear.
£120 + £10 post
Held 25psi in the upside down skip without slipping.
The clutch holds Lbft, not PSI *happy*
CR#
Member #: 1367
Cape Town, South Africa
gone/going rts?
We've gone RTS.
With out lots of psi you don't get much lbft *wink*
Also we don't know how many lbft it was making at 25psi as we never had it on a set of rollers with that much boost.
1972-ANGUS
Member #: 3894
sallys gap. garden of Ireland
Howdy,
Been a while since ive been on here, 785 posts unread, blimey!!
Is this still avail? In dublin by the way
regards
Colin
It sold a while ago.
