| Home > Help Needed / General Tech Chat > Will i benefit from just a cam change? | |||||||
5th Oct, 2011 at 08:36:30pm
Whilst my cars being rebuilt, i wanna change the gaskets on my 1275, to stop the bloody oil leaks. The only thing i dont really need to change is the head gasket so its stopping on. Whilst im doing that, i have two MG metro cams lying around, one of the later ones with the higher exhaust duration, of which many people use, and the earlier one where the intake and exhaust durations are the same, but its in slightly better condition.
5th Oct, 2011 at 09:23:20pm
later one would be better,
13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
6th Oct, 2011 at 11:44:40am
i would go for the N/A MG cam with the slightley extended exhaust duration, especially if you have the larger inlet valve on the head,...................... just as you would fit the 4th sparkpug take it to the rollers its that noticable after its set correctley !!!!!!
6th Oct, 2011 at 12:49:21pm
Ive already got a gearbox oil seal cos that drips oil everywhere, and i have the remains of a gasket kit ill use and buy what's missing, so ive got all bases covered i think! Might just chuck the early mg cam in and new valve springs, mayaswell while im there.
6th Oct, 2011 at 01:26:37pm
You'll need new followers if you change the cam.
6th Oct, 2011 at 03:12:02pm
Good point, wasn't overly thinking about it too much, i believe it can be done without taking the head off, but for what effort its going to involve ill take the head off, not like a head gasket is expensive. Id rather spend a few quid on it now and have a solid reliable engine to fall back on when the turbo lump is eventually in, im building it with reliability in mind, but i think we all know its going to be in and out a few times before the creases have been ironed out lol. On 26th Jan, 2012 Tom Fenton said:
6th Oct, 2011 at 03:29:22pm
dont forget to use that sealent on the halfmoon seal between the engine and gearbox ........apply bothsides of the seal...... on some miss mached blocks and gearboxes these are barstuards to seal if attension is not applied in that area Edited by BENROSS on 6th Oct, 2011.
![]() 392 Posts Member #: 5702 Senior Member Cornwall |
6th Oct, 2011 at 07:34:27pm
+1 on the black rtv it certainly stopped my leaks on new gaskets and seal. Just change the head gasket and the followers while your in there, also inspect all your bearings and oil pump. It is simple enough to change the cam with the engine built, but it would much trickier to do the valve springs |
