Home > Help Needed / General Tech Chat > Gt17 actuator position with matty manifold
almichie
Member #: 2065
I've got to the stage where I need to sort the actuator mount for the turbo.
I've chopped the original off that was cast into the compressor housing!
Looks like might have to do as the t2 and re weld the actuator arm?
Or is there another way?? It's bloody close to the bulkhead (no box) - I could make a bracket to the bulkhead - but if the engine moves it'll change the boost characteristics...
The Saab actuator has a very long arm.
Thanks
Edited by almichie on 6th Oct, 2011.
Shaft seems nice and snug
have a look at what we did for the metro van
I'd definitely make sure its connected to the engine, and have it sitting as the T2 does, near the master cylinders.
They are a bloody tight fit! *hehe!*
mine clears the bulkhead box... Just.
almichie
Member #: 2065
But I don't have a bulkhead cut out...
And my turbo is clocked so the outlet is up.
I'm going to look at it again tonight and try and find a way to mount it.
I think everyone has it differently!!!
jamiestevenbell
Member #: 9941
Derby
Has any one got any pictures of how there's is mounted with no bulk head box please as I just fitted my engine and its no where near where I expected it to be!
tadge44
Member #: 2500
Buckinghamshire
This is no good if the original mount is cut off, but its how I did mine
http://s302.photobucket.com/user/tadge44/m...G_0909.jpg.html
http://s302.photobucket.com/user/tadge44/m...G_0908.jpg.html
jamiestevenbell
Member #: 9941
Derby
Tadge do you have a bulkhead box?
tadge44
Member #: 2500
Buckinghamshire
Not hardly - its in a 1959 Austin A35, which is an inline setup, rear wheel drive.
jamiestevenbell
Member #: 9941
Derby
Ah I see! Thanks but I could really do with some pics of a mini one done with out the bulkhead cut
haimesyboi
Member #: 5702
Cornwall
This is where mine is;
cash74
Member #: 9946
leamington spa
i now own almichies mini ill put up some pics later
