| Home > General Chat > 4 Pot Caliper for 7.5\" Disk | |||||||
![]() 85 Posts Member #: 3600 Advanced Member Gateshead |
7th Oct, 2011 at 01:56:46pm
I am in the market for a pair of 4-pot calipers. There seem to be three choices, Mini Spares, Mini Sport and KAD. KAD ones are a little out of my price range which leaves Mini Spares or Mini Sport.
7th Oct, 2011 at 02:00:46pm
Mini spares are what you want.
7th Oct, 2011 at 02:20:57pm
No experience to speak of, but i will be ordering inspires callers later in the year On 11th Feb, 2015 robert said:
7th Oct, 2011 at 02:27:57pm
On 7th Oct, 2011 apbellamy said:
inspires callers huh? If something is worth doing, it's worth doing half of. |
7th Oct, 2011 at 02:36:13pm
Stupid phone. mini spares. On 11th Feb, 2015 robert said:
![]() 3756 Posts Member #: 1709 I like granny porn. LONDONSHIRE |
7th Oct, 2011 at 04:13:01pm
i use mini sport ones. but hey are 7.9's 4 pot still,
I bet my first wank came quicker than your first mini turbo These new modern turbos with their quick spool up time, would make the competition harder. On 15th Aug, 2011 robert said:
phew!!! thank you brett for smashing in my back doors .( not something i imagined writing... EVER) |
![]() 62 Posts Member #: 9439 Advanced Member stoke on trent |
7th Oct, 2011 at 04:28:12pm
On 7th Oct, 2011 Kean said:
Mini spares are what you want. Mini sport are terrible in my experience What kind of problems have you had? |
7th Oct, 2011 at 07:40:34pm
Mini Spares seems to be getting the vote so far by 2:1
7th Oct, 2011 at 07:47:09pm
two nipples on minispares calipers alledgedly On 11th Feb, 2015 robert said:
7th Oct, 2011 at 08:54:57pm
I have a set of early mini sport 4 pots on 7.5" non vented.
![]() 1434 Posts Member #: 8466 Post Whore Mansfield |
7th Oct, 2011 at 09:19:46pm
Ive currently got the 8.4 non vented minisport calipiers on my clubman, they have been fine, BUT my previous 7.9 Minisport set had to be helicoiled as the alloy seemed really soft and I damaged the brake pipe thread with very little effort. Minisport did this for free and said its was a common repair. Never had any problems bleeding them though. Moved to KAD now on my turbo, and they seem very good, especially with mintex 1155 pads. Edited by alaskanow0 on 7th Oct, 2011. Class C 3rd Place Avon 2011 14.18 @101mph |
8th Oct, 2011 at 04:35:20pm
I was one of the unfortunate ones to have snapped off a bleed nipple(minisport 7.9 vented), had to carefully weld a nut to the remainder of the nipple which did the trick! a smidge of copper grease went on with the replacement, hopefully will prevent the same happening again! other than that they seem a good caliper. |
432 Posts Member #: 7856 Senior Member Essex |
8th Oct, 2011 at 05:06:52pm
I have 2 sets of minisport ones:
8th Oct, 2011 at 05:54:28pm
I have a set of Minisport 4 pots on 7.5 discs, they are the ones with the inserts i had a nipple snap, so i called them up and they sent me a new set up for free.
8th Oct, 2011 at 07:37:03pm
So which pads do people use with the 4 pot 7.5 setup? I understand that there is a small mod to make to pads with the Mini Spares caliper, how about the minisport one? |
1 Posts Member #: 9633 Junior Member |
8th Oct, 2011 at 07:58:23pm
Hi guys,
![]() 825 Posts Member #: 2208 Post Whore Essex |
9th Oct, 2011 at 04:26:47am
if it helps,
9th Oct, 2011 at 10:18:17am
On 8th Oct, 2011 svrdaniels said:
So which pads do people use with the 4 pot 7.5 setup? I understand that there is a small mod to make to pads with the Mini Spares caliper, how about the minisport one? Yes, you have to trim the 2 corners off of one pad on each caliper with both mini sport types, but it's not exactly hard to do so I wouldn't be put off by it or anything! |
