Home > Help Needed / General Tech Chat > gasket help
998-city-rat
Member #: 9421
Bardwell, suffolk
I'm after some gearbox speedo housing gaskets is it possible to buy the gasket on its own with out buying a complete gearbox rebuild kit? Rang mini spares but out of stock!!!!!! Again :(
I'm sure I have some spare. can you be specific about which ones.
998-city-rat
Member #: 9421
Bardwell, suffolk
Cheers will its the gasket that is kind of d shaped with a thick side if that helps I'll see if I can't find a part number if that would help?
The one that actually sits between the main box and the speedo drive casting?
Do you need any of the other little ones on the speedo drive?
Answer in a PM with your address and I'll bob them in the post later.
