Home > Technical Chat > what turbos fit ?????
minidan
Member #: 7107
essex
hi all
im using a mirage setup with r5 turbo exhaust housing for my turbo install just wondred what other comp housing and cores i can use with this exhaust housing
thanks dan
Edited by minidan on 8th Oct, 2011.
Unfortunately I cannot help you with your problem, but it Might be an idea to change the topic title to something a little more descriptive and helpful?
alaskanow0
Member #: 8466
Mansfield
You will be limited on comp housing due to clearance with the block. You can use a t25 bearing housing, either water or air cooled. I found the only way to increase flow was to bore out the r5 housing and install a larger comp wheel from something like t25 or t28, but be careful, as my turbo doesnt reach full boost until 6k. I'm now opting for a gt17 on new manifolds.
where did you get the boring done?
alaskanow0
Member #: 8466
Mansfield
I had the complete turbo built and balance at turbo centre Uk. Wasnt cheap and not really worth the effort. A new genuine gt1752 would have been £300 cheaper.
