Home > Help Needed / General Tech Chat > Running in oil!
Craigie-B
Member #: 9468
Wootton Bassett
So i was doing a search for running in oil and it came up with duckhams 20w 40
However i cant find some anywhere, what do you guys use and is that halfords classic oil with the mini on the tin any good?
Craig
Unipart green is good,
Craigie-B
Member #: 9468
Wootton Bassett
Is that good to use after running in aswell?
jamie@thefatgarage
Member #: 9345
Sheffield
You can get a gallon of 20/50 comma from Parkers motor factors for about £12, fine for running in. If it's going to do 500miles and get chucked then it doesn't matter. Then spend a bit more on decent oil. Lots of threads on here about oils...
minirsp
Member #: 2154
Stockton on tees
You can also find the coma 20-50 in your local boys or nisa
Darren
Penrite specific 20w50 running in oil *wink*
Halfords classic is shite
Edited by Sprocket on 9th Oct, 2011.
dazibee
Member #: 1356
TRURO, CORNWALL
Please elaborate. Whats the matter with Halfords Classic?
you get rocker mayo after about 10 minutes *tongue*
Alex
Member #: 1851
Woolavington, Zummerzet
Unipart 20w50 for older engines - has the correct ZDDP levels according to the can.
I had to pull the engine out of my wife's GT after 300 miles (spun big end) and the cam followers etc looked lovely.
Millers do a specific running in oil
Craigie-B
Member #: 9468
Wootton Bassett
Awsome thanks for the advice guys *smiley*
in homebase yesterday they had 5 litres multigrade for 8.96 i think it was ....cheap!
We are using the standard Halfords mineral 20-50W, not the classic stuff.
im running the same as the metty van i think, and likely the same as Paul s, i got the end of line stuff before the re brand @ 4quid a gallon ( i bought the lot )
turbominij
Member #: 2104
Essex - UK
i use valvoline vr1 20w50 and have for years and not had a problem with it when i took the gearbox off my old engine it still looked new.
"Tuning should be a compromise between what is possible and what is necessary"
10)Thou shalt always quest for more power
