Home > Help Needed / General Tech Chat > under crown oil cooling jets
dazer1985
Member #: 9614
Burstwick, Near Hull, East Yorkshire
after reading turbo phils site im looking to build an engine with decent power, i was interested in trying the under crown piston cooling idea as i have got chance of getting my hands on a full set of mondeo 2ltr diesel cooling jets. Has anybody used these type with good results or is there a better jet out there??
the bimmer ones are the ones to use,
part no in here somwhere,
http://www.turbominis.co.uk/forums/index.p...&tid=5512&fr=50
Amp
Member #: 7856
Part number is 11 11 1 739 907. They came to £42 or around that figure when I bought them, but that was some time ago!
*the above code is for the BMW ones that Joe said*
Edited by Amp on 9th Oct, 2011.
I have the BMW one for my block. piece of cake to fit. They are basically an M8 banjo bolt.
I say the where easy, but I just gave them and my block to fast carl and picked it a few days later. easy as.
dazer1985
Member #: 9614
thanks for the information on which are better think ill have to get some BMW ones.
Another thing is where is best to get the machining done for this as i dont trust my local engine machinists (had some bad reviews)
Amp
Member #: 7856
Well that depends entirely where you are located unless your willing to courier it to someone?
minidan
Member #: 7107
essex
im thinking of going down this route to im in essex can anyone recomend a machine shop in essex ??
topcat
Member #: 9408
Tiptree, Essex
Thurston engineering
www.topcatcustom.co.uk
Ive heard good stuff about thurston's but not used them,
where in essex are you? Ive used R&M in maldon a few times for block skims and the like,
Thutstons are very good.
minidan
Member #: 7107
essex
im in ockendon has anyone used gosnays on the a12??
