| Home > Help Needed / General Tech Chat > phase 2cam (chain stretch) | |||||||
461 Posts Member #: 9229 Senior Member newcastle upon tyne |
10th Oct, 2011 at 08:17:43pm
hi iam getting my engine built at the min with a phase 2 cam i know it needs timed in at 108deg but iam useing new duplex gears & chain should i time it in at 106deg to allow 2deg chain stretch? as iam unsure what to do for the best opinions please guys thanks scott |
10th Oct, 2011 at 09:21:16pm
I don't think a modern duplex will stretch much at all. With a 5 port timing a couple of degrees either way makes little difference as what you lose on the inners you gain on the outers and visa versa (according to Mr Vizard - Tuning BL's A series Engine - A talk by David Vizard - Part 6) |
![]() 207 Posts Member #: 9045 Senior Member Wolverhampton, West Midlands |
10th Oct, 2011 at 10:08:12pm
My duplex has stetched quite a bit TBH. To a point where im going to refit the tensioner this time round aswell as re-checking cam timing. |
10th Oct, 2011 at 10:37:33pm
there are cheap chains and quality chains, i believe the quality chains dont stretch much
Yes i moved to the darkside |
11th Oct, 2011 at 08:10:29am
Well to be honest the new gear & chain set cost 24pound so its no piper or kent item so iam thinking its going to have some chain stretch |
11th Oct, 2011 at 09:24:53am
106 degrees is good. On 13th Jul, 2012 Ben H said:
11th Oct, 2011 at 09:35:21am
My Phase 2 is timed in at 106 on a pre-stretched chain and it idle's as smooth as a cashmere codpiece. The van's is timed at 110 and needs a few more revs to smooth it out.
11th Oct, 2011 at 10:54:48am
Well 106 it is I see how it goes thanks lads |
11th Oct, 2011 at 11:54:12am
Hmmmm I went with the included times and used a pre stretched chain to 110....
11th Oct, 2011 at 12:00:53pm
Should be fine Al. It's not a bother on van. It just doesn't tick over at 800rpm (nearer 1000rpm)
11th Oct, 2011 at 12:52:50pm
12th Oct, 2015 at 07:54:20pm
Thread revival!!!
My build thread..
13th Oct, 2015 at 07:30:34am
JT USUALL 1 DEG per 1000 revs pick up or loss, t
Edited by BENROSS on 13th Oct, 2015.
13th Oct, 2015 at 07:26:45pm
Thanks Steve.
My build thread..
14th Oct, 2015 at 07:48:48am
Hi JT, Found that every one degree. Of advancement from 110 degree. On the phase 2 pulls the bottom. End up around 500 revs, but don't go over board.
14th Oct, 2015 at 09:30:29am
Ok thanks Steve. I might leave it at 110 as I'm going to set the rev limiter at 7000rpm. I can live with a slightly lumpy idle as I have a sw10 cam in now (na1380)
My build thread..
