| Home > Help Needed / General Tech Chat > ATT JUKKA | ||||||
14th Apr, 2005 at 09:33:53am
hi jukka got my 1380 on the road now as you may be a aware, every thing is going great except for a problem at 4k after a good thrash, any way spoke ray at my rolling road and he recon it may be 2 things, one my t piece before the pump may be a problem . always looking for them bigger bunches of bannanas |
14th Apr, 2005 at 09:47:37am
I have normal steel t-pieces, both for connection between the tanks and return line to pump inlet line.
14th Apr, 2005 at 10:16:27am
i'm also using a T piece return like the pics jukka sent me. standard outlet on the tank aswell. i havent had any problems with it at all. On 20th Oct, 2015 Tom Fenton said:
14th Apr, 2005 at 11:35:26am
he is what i put in the other post.
14th Apr, 2005 at 11:38:52am
it will rev on low boost past 4 4.5k but on say 7 psi it will rev put after a period of time it develops a mis fire at 4-4.5 k but off boost she runs fine back on boost fine until i hit this point , its namely in 3rd and 4th. always looking for them bigger bunches of bannanas |
14th Apr, 2005 at 12:02:11pm
If the t-piece setup would create problems at 7 psi it would do it everytime. Since it sometimes works and then not the problem is most likely elsewhere.
14th Apr, 2005 at 12:13:08pm
just a thought !!!!
14th Apr, 2005 at 03:58:54pm
ive got vents every were rs turbo vents plus 1 right above carb opening facing the windscreen.
16th Apr, 2005 at 08:55:53am
What do you mean about the coil benross do they cause this when they need replacing? (sorry to butt in but i didnt know how faulty coils occur :) ) Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
16th Apr, 2005 at 10:27:49am
feeb
