Home > Wanted > Layshaft/Reverseshaft locking tab
Tareq
Member #: 970
Bahrain
Hi
I've misplaced the locking tab for the layshaft/reverseshaft.
Its a 1275 A+ gearbox.
Anybody got one please.
can you show me a pic, i have the contents of a gearbox in a tub in the workshop
carl
Tareq
Member #: 970
Bahrain
Hi Carl,
Its the bit circled in red.
Was meaning to email you. Am looking for the bits to connect pipe for drydeck pipe.
In Ali though.. Not rich enough for titanium!
Thats not reverse, thats on the main shaft, reverse and its shaft are directly above the part you have circled,
btw i don't have any of these lock tabs in any of my three gearboxes in use .
send me a PM re the waterports,
carl
Looks to me to be the layshaft and reverse shaft locking plate. The one with the single bolt hole that fits behind the third motion shaft bearing retainer?
I should have one, I'll look it out. I owe you a favour anyway *wink*
Edited by Sprocket on 15th Oct, 2011.
Tareq
Member #: 970
Bahrain
Hi Sprocket, thats the one. locking plate not tab. If you have one would be a life saver thanks.
Carll.. PM sent
Tareq
Member #: 970
Bahrain
Carll.. PM sent
Tareq
Member #: 970
Bahrain
Aas I cant find the gearbox man and am desperate for a few bits maybe someone might have these for sale.
locking plate for reverse/layshafts
18mm Nut for the pinion
Primary gear locking washer and c-washer
Thanks
Tareq. If noone in the UK can help you I can. Please let me know.
I think I've got the nut for the pinion. Is the 18mm one the A+?
Tareq
Member #: 970
Bahrain
Thank Vegard, just found a nut on ebay
Hopefully it fits!
I sent out two locking plates the other day. They do have a little wear on them but don't they all? I selected two of the best for you :)
Do you still need any of the other parts? Do you want me to send out another package? No problems if you do.
Tareq
Member #: 970
Bahrain
Fantastic Sprocket, much appreciated.
I think I might have found the other bits
Thanks again for the help!
Tareq
Member #: 970
Bahrain
Thank you Sprocket. Recieved the package today. You are a life saver.
you are welcome. let me know if there is anything else i can help with.
