| Home > Help Needed / General Tech Chat > installing megajolt - no spark! | |||||||
15th Oct, 2011 at 11:06:23pm
Evening all
15th Oct, 2011 at 11:47:32pm
make sure the crank sensor is close enough to the trigger wheel, unplug megajolt and try see if it fires on the edis alone Yes i moved to the darkside |
15th Oct, 2011 at 11:50:15pm
i have yet to attatch the megajolt so only the edis is in the car at the moment. the sensor is around 1mm from the pulley. the live feed to the edis and coil pack are live when cranking also. |
15th Oct, 2011 at 11:51:41pm
Could be the VR sensor wires around the wrong way and not sending a signal. The is some checks at the bottom of the MJ page
15th Oct, 2011 at 11:57:51pm
cheers, we will look into this tomorrow. we managed to test the vr sensor and it showed 0 at standstill but only 0.2 when cranking so this may be the problem? i have looked on ebay and it looks like you can get the whole ford hardware for under £40 so this may also be a good idea - it would be handy to have a spare. i will definately check the vr wires, it seems this is a very common error when wiring this setup in. cheers |
16th Oct, 2011 at 12:49:23am
the vr sensor will send a +/-ve spike every time the raised section on the trigger wheel passed
16th Oct, 2011 at 09:44:22am
We spent ages fooking about with benny's car trying to get a spark. It turned out he had metal swarf on the face of the sensor which was confusing it. Cleaned that of and got a spark straight away. On 11th Feb, 2015 robert said:
16th Oct, 2011 at 03:19:08pm
cheers for the input. i will check these and let you know how i get on. i checked the wiring to the crank sensor, all is well so i can rule that out. cheers, dan |
16th Oct, 2011 at 04:15:19pm
thanks for the input - this problem is now solved - the sensor had swarf on it and i now have a good spark - many thanks again. maybe this is a sign for me to get my arse in gear and not leaving it hanging around any longer! going to get the ic etc back on, sort the rest of the electrics and fit the fuel tanks, i should be good to attept to start it on my next free day! |
16th Oct, 2011 at 04:21:23pm
18th Oct, 2011 at 10:36:41pm
yea very useful! its one of those things that you could end up chasing for a long time to finmd the fault - i thought the ford hardware was duff so you saved me a couple of quid too! we have sorted most of the electrics now so just the fuel tanks to fit and refit the intercooler and we should finally be ready to attempt to fire it up! cheers |
