Home > General Chat > Bulkhead box
PEP
Member #: 1145
North Wales
Awright guys??
Ive got a clubby and its been sat for years. Finally got it to the bodyshop.
I was told it was running a turbo engine etc-question is do i bother putting in a bulkhead box whilst ive got the chance?????????????.
ps.sorry for the stupid question.
Many thanks
No. The best option is to buy/have made an exhaust manifold that will allow the turbo to fit behind the block without any modification to the bulkhead.
nutter driver
Member #: 47
Not very sunny swanage
depends... A bulkhead box is almost certainly the cheapest way of getting a turbo engine into a mini, although not necessarilly the best (see wil_h post above)
Another thing you may wish to take into consideration is that by fitting a bulkhead box, you are tecnically modifying the monecoque, and in doing so, you will be falling into the 'needs a biva' test catagory.....
Its possible/probable that no-one will ever report you, and you will never have any problems, but i must admit, if iwas starting again, i wouldnt have bothered with a bulkhead box, especially as im now on a t2 turbo.....
Im fitting one to mine, but then again ive already cut the front end off. I think it was looked at in mini mag about these tests, and its really only major things they will pull you up on, such as fitting a v8 or something silly sized. Basically anything considered to be a 'major' alteration. At the end of the day, rover fitted them to the ERA, so whos to say it cannot be done, unless someone really wants to be a pita. Personally, if my car was untouched id fit a mirage, if its under resto id fit a box.
