| Home > Help Needed / General Tech Chat > hi i need help with my mg metro turbo can you help me out thanks | |||||||
37 Posts Member #: 9647 Member weston-super-mare |
18th Oct, 2011 at 06:39:30pm
18th Oct, 2011 at 07:25:24pm
Check the relay On 19th Jan, 2010 wil_h said:
18th Oct, 2011 at 07:38:02pm
hi thanks for your reply i have check the relay it is working and i have put a new oil pressure switch in and new oil and new oil filter thanks dean |
18th Oct, 2011 at 08:21:49pm
There's also the resistor thingy that drops the voltage to the pump. not sure where it is on the car On 11th Feb, 2015 robert said:
18th Oct, 2011 at 09:54:01pm
thanks for your reply i have a look for it thanks dean |
18th Oct, 2011 at 10:03:25pm
The resistor is under the battery tray. |
18th Oct, 2011 at 10:20:51pm
hi big thanks for letting me no where it was thanks dean |
19th Oct, 2011 at 04:15:35am
Is your new oil pressure switch the correct one for a Metro Turbo ???
19th Oct, 2011 at 01:54:56pm
hi thanks for your reply it is the correct one buy it from car shop buy me thanks dean |
19th Oct, 2011 at 01:59:57pm
to elaborate on what rod said,
hi my name is dean i am new to this site i have a mg metro turbo the fuel pump is working of a battery but the wires going to the pump are dead can you help me out thanks dean :)
