| Home > Help Needed / General Tech Chat > tucked wheels | |||||||
22 Posts Member #: 9602 Member Ipswich - East Anglia |
20th Oct, 2011 at 05:47:58pm
is it possible on a mini to get both the front and rear wheels tucked right under the arches without any arch mods (as in cutting)?
20th Oct, 2011 at 06:04:39pm
The look of your Golf is not really achievable on a mini as far as I am aware.
20th Oct, 2011 at 06:13:33pm
Oh, and in addition you'd look like a giant cock. On 13th Jul, 2012 Ben H said:
20th Oct, 2011 at 06:28:41pm
i wasnt looking at going quite as low as the golf, i only posted that picture so that people understood fully what i was talking about.. where would the rad arm foul? im not disputing it, as you know what your talking about, im just have trouble picturing where it would foul??
56 Posts Member #: 5200 Advanced Member Bath, Somerset |
20th Oct, 2011 at 06:30:26pm
Isn't that picture a Yugo? |
![]() 2057 Posts Member #: 9252 Post Whore Cleethorpes |
20th Oct, 2011 at 06:31:21pm
the subframe id of thought. to get that look you may have to modify the rear quarter panels Edited by wng691s clubby on 20th Oct, 2011. Done now needs redoing lol |
20th Oct, 2011 at 06:46:59pm
The radius arm fouls the area where the vertical section of the inner arch joins with the boot floor. You'll crush the brake pipe first, but you can buy long braded pipes and move it out of the way. You could hammer part of the lip flat wher ethe radius arm fouls this will give you a little more, but the radius arm will still foul the boot floor.
20th Oct, 2011 at 06:48:26pm
The radius arm fouls the body seam between the boot floor and the arch that runs above the radius arm.
20th Oct, 2011 at 06:52:45pm
Spat beer all over my monitor when I read that... but it was worth it!
On 20th Oct, 2011 Vegard said:
Oh, and in addition you'd look like a giant cock. |
20th Oct, 2011 at 07:00:04pm
The top and bottom of it is, without cutting stuff apart, it won't happen, the best you'll do is buy some wider wheels and some arches with no return, and mount the arches as low as possible and drop the car a bit on hi-los.
![]() 22 Posts Member #: 9416 Member durham |
20th Oct, 2011 at 08:47:29pm
How about using some of the McLeans Bros Mexico arches, you will need to run some wide 13" wheels but it might get the tucked look your after. Other than that your going to need a large hammer! and alot of luck. |
20th Oct, 2011 at 09:08:09pm
Or go vip style with massive camber, i have thought about this and i think it could be done with rolled arches and lowered, run some reverse steels raise the front subby and inch by the 'miglia' mod, redo the mounting points and slamm it abit the drop the back down so tyre will be under but not the whole rim sort of how some of the drifters do it on escorts and ae86's. I love slammed cars and wish to do something to mine when its at the right stage but will probably be arch extension dropping to create the lower look Drives
20th Oct, 2011 at 09:52:58pm
On 20th Oct, 2011 Paul R said:
raise the front subby and inch by the 'miglia' mod, redo the mounting points You'll never get an extra inch without serious modifications to the cbulkhead crossmember. It's more like 1/2" On 26th Oct, 2004 TurboDave16v said:
59 Posts Member #: 9435 Advanced Member eire |
20th Oct, 2011 at 10:01:51pm
this was gonna be my option also, the only way realy is to rais all mounting points as sugested including the majority of the boot floor... it is achievable without touching any of the arms but the arches might need to be extended slightly for them to go over the tyres.
Or go vip style with massive camber, i have thought about this and i think it could be done with rolled arches and lowered, run some reverse steels raise the front subby and inch by the 'miglia' mod, redo the mounting points and slamm it abit the drop the back down so tyre will be under but not the whole rim sort of how some of the drifters do it on escorts and ae86's. I love slammed cars and wish to do something to mine when its at the right stage but will probably be arch extension dropping to create the lower look |
20th Oct, 2011 at 10:22:42pm
Mine is at the limit of low trust me you cant go low enough with the std front suspension arms and the boot floor to do what your describing... And the mini doesnt exactly have arches to roll
Yes i moved to the darkside |
![]() 553 Posts Member #: 1356 Post Whore TRURO, CORNWALL |
20th Oct, 2011 at 11:41:18pm
And beware of the front ball joints locking up and breaking if you go low enough to tuck your wheels in. You might need to run your exhaust inside the car with you too because otherwise it will be ripped off the car the first time you go out in it. |
20th Oct, 2011 at 11:43:27pm
No forget running the exhaust inside with you that's just daft, I meant fit sidepipes instead.
Edited by dazibee on 21st Oct, 2011. |
21st Oct, 2011 at 12:03:34am
Bollox to that just bring the selector box in and tuck the exhaust Yes i moved to the darkside |
667 Posts Member #: 1376 Post Whore clock tower with a sniper rifle |
21st Oct, 2011 at 08:01:52am
4,5 minilights, non spacered drums, 145 tires, no tubbing maybe raise arch "roof" for greater suspension travel
internationally known as "big" swede |
