Home > Help Needed / General Tech Chat > Clutch arm position?
tomkidd
Member #: 1962
Lancaster
I'm trying to figure out if I've done something obviously wrong here... Have I done something stupid? It looks like I won't be able to get the holes to line up unless the clutch is pressed in slightly? I couldn't get the rod and further into the slave cylinder either. Any ideas?
Edited by tomkidd on 26th Oct, 2011.
piston in the slave all the way in?
I have to push my one in to mate.
On 26th Oct, 2011 madmk1 said:
I have to push my one in to a mate.
simon... simon tooo much info *happy*
Sorry,
I was only chatting about pushing my rod into the slave.
Edited by madmk1 on 26th Oct, 2011.
If the clutch is bled, take some fluid out the reservoir and try and push it in further, if it doesn't, no harm done.
tomkidd
Member #: 1962
Lancaster
Sorry,
HA HA! Cheers mate
tomkidd
Member #: 1962
Lancaster
Currently its just on the bench with no fluid etc, I was just offering it up.
I think I'll try again when the engine is in the engine bay.
Out of interest the circular plate that the plunger presses (and has the spring clip holding it one) against has a raised section, should that be facing outwards or inwards?
I wondered if that was the wrong way round that it would not let the plunger go in far enough...?
outwards iirc, a few have assembled it backwards recently, you dont get a clutch basically
tomkidd
Member #: 1962
Lancaster
Cheers guys, just had a play with it all and the slave cylinder had stuck... I gave it a little knock and it went in further.
Told it was a stupid mistake.
