| Home > Help Needed / General Tech Chat > Good CV Joints | |||||||
28th Oct, 2011 at 07:56:58pm
Looks like I need a new Inner pot joint, so where is the best place to get them as I will do the 2 as i am at it.
Edited by madmk1 on 28th Oct, 2011. I have started posting on Instagram also my name on there is turbomk1golf
28th Oct, 2011 at 08:33:25pm
Be warned!
28th Oct, 2011 at 08:37:55pm
My one is some how slipping. I have started posting on Instagram also my name on there is turbomk1golf
28th Oct, 2011 at 08:40:51pm
How are your balls? |
28th Oct, 2011 at 08:49:59pm
I had a right bastard of a time getting a pair of new pot joints off the diff output shafts. Ended up taking the whole diff off the gearbox in one and taking it to a bloke with a gurt big vice, mounted on an uber heavy steel bench then eased them off with a big fucking hammer. The spring clips broke in the process and the joints rendered useless. All that extra trouble to save a few pennies? and note, It was not me saving the pennies!
28th Oct, 2011 at 08:50:33pm
I have not looked yet, but when i go to drive it, it makes should a bang!!
28th Oct, 2011 at 08:51:27pm
28th Oct, 2011 at 08:53:39pm
[quote=Sprocket,28th If there is any doub't, I'd always take a punt with Minispares, as you do at least get an honest description in most of the cases.[/quote]
28th Oct, 2011 at 09:01:55pm
Right I know F all about the metro, so will a up to 1990 metro inner cv fit as well?
28th Oct, 2011 at 09:47:03pm
I THINK the metro cv's are smaller. Im sure ive had to swap some over before because my box had some on that were too small. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
28th Oct, 2011 at 09:49:37pm
There were some that had smaller, err.. ball areas. These will be like a chipolata in a wizard's sleeve...
28th Oct, 2011 at 10:18:40pm
Like this http://www.ebay.co.uk/itm/AUSTIN-METRO-INN...=item588fd25630 I have started posting on Instagram also my name on there is turbomk1golf
29th Oct, 2011 at 02:52:03am
The metal parts of the metro ones are essentially the same - I used the ones from my Metro donor engine without any problem - but as you can see in the eBay photo, the boot arrangement is completely different and has to be removed as it doesn't fit on a Mini drive shaft. The Mini boot did fit in my case but the locating groove for it was slightly different IIRC.
1st Nov, 2011 at 09:13:35pm
Looks like Minispares did sell them for minis so i think i will get some
203 Posts Member #: 1734 Senior Member Lancaster |
2nd Nov, 2011 at 10:40:37am
I also had these problems with an inner CV not coming off due to the circlip sticking. I seem to remember knocking out the little metal centre disk in the pot and use a 3 legged puller though in the end? |
