Home > Technical Chat > GT17 A/R
viz139
Member #: 9182
Currently running a standard Metro Turbo setup but looking at building a second fast road car based on a mirage manifold with a GT17 and a Avonbab Ph2 cam. The turbo of choice seems to be the Saab GT1752 with an A/R of 0.47 but I have seen other GT 17 with A/R ranging from .40 to .56 .What is the optinumn A/R for any engine and how far should you variey up or down from it. I know its a general question with many engine variations but did somebody just find the Saab turbo by luck or by calculation.
viz139
Member #: 9182
Is there something wrong with the question or is this an unexplored area.Doing a search the only comparison I can find is were people have had T3 reconditioned from standard .25 to .36 and found it better .More info the range of A/R usable opens the door to using some diesal turbos which I'm finding easier to source secondhand at lower prices.
Changing turbine A/R is largely unexplored. The proven theory is that a lower A/R will reduce the boost threshold but may limit top end power and vice versa.
Personally I think that the higher A/R will work well with higher duration cams as well. The PH2 is a good cam but was developed for use with T3s. Someone should try a 276 with a GT1752 IMHO.
BTW Robert worked out that the GT1752 would be a good turbo for a 1275 based on his long experience with turbos.
steve1275
Member #: 951
Bromsgrove
I have a GT1752 on a Matty manifold and 1.5 rockers.I found the max torque speed around 5000rpm with a 276 cam.Fitting the ph2 turbo cam brought this down to 4000 rpm AND mysteriously seemed to give more top end power.
'Where does the engine go?'
