Home > Help Needed / General Tech Chat > Running sweet but dosnt seem to boost.
turbo22
Member #: 3684
wisborough green west sussex
Took the mini for an mot and first drive today and all seems to be good and the mini is running sweet but i dont seem to be getting any boost. I can rev right up to about 4k but nothing seems to be kicking in and i cant hear anything from the dumpvalve. Also boost guage dosnt seem to be moving at all though i think that might just be a faulty guage. Has anyone got any ideas?? Please help.
bennyy
Member #: 9037
Doncaster, yorkshire
Does than gauge not move st all or does it read vac when not under load?
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
turbo22
Member #: 3684
dosnt move at all. I have another cheap guage that im gonna test now but this cant be the prob can it?
I'd start by looking at the wastegate.
turbo22
Member #: 3684
i have also noticed it seems to have used a fair amount of fuel for the short distance i drove.
turbominij
Member #: 2104
Essex - UK
Wastgate not staying shut I recon make sure it's hard shut, extend the actuator adjustment a hols with past here it clips on to the wastgate then refit the actuator to the wastgate this will make sure it's closed properly. Then up the preload till the desired boost is reached.
Edited by turbominij on 3rd Nov, 2011.
"Tuning should be a compromise between what is possible and what is necessary"
10)Thou shalt always quest for more power
turbo22
Member #: 3684
Will do that now Ta.
turbo22
Member #: 3684
right problem sorted, waste gate and actuator adjustment was set wrong. Im now boosting and all is good, though it still dosnt feel like the bhp im expecting.
Ten you need to get it setup
turbo22
Member #: 3684
Think im gonna give it 500 or so miles then get it setup on the rollers. Gonna have to get the camber/caster set sooner though as it seems to be a bit twitchy. Boost seems to kick in at just over 3krpm, does this sound right?.
as the guys say get it set up on a RR Pronto!
Get it on the rollers if you are unsure on the fueling. It'll help bed the rings in anyway. *happy*
