| Home > Help Needed / General Tech Chat > Detecting cracks in cylinder heads | |||||||
![]() 1547 Posts Member #: 2727 Post Whore Bicester |
8th Nov, 2011 at 09:17:19am
Hey guys,
1972 998 TURBO SLEEPER |
8th Nov, 2011 at 09:50:00am
i would take it to your local machine shop ....it they are good they place it on a UV lamp with dypen,
8th Nov, 2011 at 11:30:14am
Cheers i'll dig out me magnifying glass lol 1972 998 TURBO SLEEPER |
8th Nov, 2011 at 11:37:23am
get the chambers blasted. They will be easy to see afterwards. |
8th Nov, 2011 at 12:45:37pm
Blasted:
8th Nov, 2011 at 12:54:57pm
Thanks guys, ive convenantly got a Micro Grit blaster at work which will bring those chambers up a treat 1972 998 TURBO SLEEPER |
8th Nov, 2011 at 02:07:05pm
If your anywhere near doncaster anytime or can cover postage both ways I can do this for you free of charge. Edited by bennyy on 8th Nov, 2011. Audi s4 b5 - 470bhp & 486ft lbs
On 15th Mar, 2012 wil_h said:
8th Nov, 2011 at 02:09:52pm
Blasting or crack detection? If something is worth doing, it's worth doing half of. |
8th Nov, 2011 at 02:10:46pm
Crack detection john. Audi s4 b5 - 470bhp & 486ft lbs
8th Nov, 2011 at 02:12:56pm
8th Nov, 2011 at 02:21:25pm
As for the household methid, there is a very old fashion technique called the oil and whiting method, its very similar to the modern day dye penetrant inspection, just much less sensitive, oil is applied to the surface being tested and left to penerate the fine surface breaking defects, the excess surface oil is removed and a chalk powder is applied, which works as a blotting agent and creates a bleed out, obviously I can do a much better job with modern consumables, or could be done by magnetic particle. Audi s4 b5 - 470bhp & 486ft lbs
8th Nov, 2011 at 03:59:20pm
Cheers for the offer Bennyy but sadly Oxford is no where near Doncaster. I'll have a good going over with the magnifying glass. I plan to have some work done at Rob Walker Engineering as its local so will get him to double check it
8th Nov, 2011 at 07:38:28pm
Not a problem mate. Audi s4 b5 - 470bhp & 486ft lbs
11th Nov, 2011 at 08:39:53am
Here's a casting I scrapped this morning, non of these cracks were visible to the naked eye, no matter what the surface condition is, nor will you see them with a magnifying glass, if just given a visual inspection this would of passed exept a few areas of porosity, look what dye pen. Has found.
11th Nov, 2011 at 09:04:04am
11th Nov, 2011 at 09:08:17am
The one at the bottom is just a lump of sand that absorbs the dye Audi s4 b5 - 470bhp & 486ft lbs
11th Nov, 2011 at 09:10:26am
Cheers bennyy for the post that really does make you think. 1972 998 TURBO SLEEPER |
