| Home > General Chat > OT House electrics, any sparkies on here? | |||||||
8th Nov, 2011 at 12:08:36pm
Hi Guys, I undertand thats it's quite common to have leakage to earth in house electrics, but how much is acceptable?
8th Nov, 2011 at 01:44:16pm
We use an ac earth leakage detector for ac circuits, which puts a dc current on the busbar.
8th Nov, 2011 at 01:51:24pm
Quinton is a sparky Crystal Sound Audio said:
8th Nov, 2011 at 01:54:06pm
On 8th Nov, 2011 wil_h said:
I could probably lend you my testees.
8th Nov, 2011 at 02:06:26pm
Thansk will that may be an option.
8th Nov, 2011 at 03:31:06pm
Computers and electronics leak down to earth, so if you have stuff plugged in it will give a false reading, so make sure you have everything unplugged. You should not see any reading at all with everything unplugged, there should be no voltage down to earth, unless there is a fault, or as can happen there's a neutral connected up wrong somewhere if there's still a reading. I've had a slight tingle off some steel conduit on a pub the once removing a box lid, neutral connected up wrong on the circuit :/ On 26th Jan, 2012 Tom Fenton said:
976 Posts Member #: 3228 Post Whore North of the Netherlands |
8th Nov, 2011 at 04:31:44pm
The earth leakage circuitbreakers in the Netherlands are rated 30mA anything above that trips the switch and cuts power. (which is quite high as 50mA could kill you easily)
Dazed and Confused.... |
8th Nov, 2011 at 05:45:58pm
As already said appliances such as computers & cookers will leak to earth. Do you have any RCD's fitted Jim ? If so any leakage above 30mA will trip it anyway. |
492 Posts Member #: 3684 Senior Member wisborough green west sussex |
8th Nov, 2011 at 05:59:50pm
As long as it is a 30ma trip! which it should be if your fuseboard is to current regs. |
![]() 489 Posts Member #: 9159 Senior Member Devon |
8th Nov, 2011 at 06:32:50pm
What is the actual problem which your having? |
10th Nov, 2011 at 12:18:13pm
I do have 30ma RCD fitted.
10th Nov, 2011 at 12:19:57pm
I'll give you a tip jim. Don't pee in the sink until you fix this! lol If something is worth doing, it's worth doing half of. |
10th Nov, 2011 at 01:21:12pm
thanks John, I knew you loved me, good tip! On 15th May, 2009 TurboDave said:
10th Nov, 2011 at 02:01:24pm
What you measured from earth to neutral can be created by electrical items such as fluorescent lights, transformers, computers etc. they connect the neutral and live together directly and can give voltage back on to a neutral.
10th Nov, 2011 at 03:51:52pm
what about removing the copper pipes going to the sink and using hep Crystal Sound Audio said:
10th Nov, 2011 at 04:45:46pm
If your house is wired for PME (protective multiple earth) - and most are nowadays - a lot of what has been said above is incorrect.
10th Nov, 2011 at 07:47:37pm
as above but earthing to the water pipes is NOT the norm now and has been for many years,
10th Nov, 2011 at 07:59:09pm
The water, gas or oil pipes etc still have to be earthed Steve, within 1 metre of where they enter the premises iirc. |
10th Nov, 2011 at 09:57:53pm
The main water, main gas and oil [if present] pipes DO need to be bonded.
Edited by jamestar on 10th Nov, 2011. |
10th Nov, 2011 at 11:55:24pm
On 10th Nov, 2011 jamestar said:
or your problem could lie with something as simple as recieving a static shock from sink from walking across the floor. Very possible, especially with some types of vinyl flooring, and also depending on clothing as well. The electrical discharge isnt happening because of the electric supply having a problem. It's simply discharging static built on on yourself to earth via the first metal object you touch that is connected to earth Is it a recent problem, or been happening for a long time ? Is there an RCD fitted to any or all circuits ? 9.85 @ 145mph
![]() 62 Posts Member #: 9439 Advanced Member stoke on trent |
11th Nov, 2011 at 04:00:44pm
Ive seen it where a farm with poor electrics in its outbuildings has leaked voltage into the ground which has then been picked up by a property 300m up the road and shown as voltage on the earth..took a while find that one! |
11th Nov, 2011 at 07:56:31pm
right phil, jimster just bond everthing in the house .....lol door knobs included ....lol
1713 Posts Member #: 8480 MS Paint flat cap champion & Morris Ital Lover From Sheffield now live in York tha noz |
11th Nov, 2011 at 08:20:13pm
Dont suppose you have had a new boiler recently? Im not saying this is happening in your case but I have seen this exact thing happen when systems get rid of the hot water cylinder-you loose the only water system earth which is through the immersion heater, if there is no cross bonding and a break in the cold water pipework from the main bond then what you descibe has happened-36v on the sink as i recall.
Edited by oli79 on 11th Nov, 2011. On 18th Oct, 2013 apbellamy said:
I am feeling particularly BACish today. On 5th Oct, 2014 Shauna said:
What that's crazy, you go commando hahaha! How heavy is your helmet ? The Morris Ital assassin! |
11th Nov, 2011 at 11:35:18pm
^ was any of that english?
