| Home > Technical Chat > Camshaft question. | |||||||
6 Posts Member #: 484 Junior Member |
17th Apr, 2005 at 12:17:00pm
I am new to this turbo game and I have just bought a metro turbo which I am removing the engine from, and while I have the engine out I was for fitting a cam. My question is can a Avonbar phase 2 cam be fitted to an otherwise standard Turbo engine? I will be tuning it furthur in the future but to start with it will be standard, but I would like to change the cam while the engine is out as most other mods could be done it situ. Also would the Phase 2 be better than an MG Metro cam, I am not worried about the extra cost if i thought it would make a difference? |
17th Apr, 2005 at 12:24:37pm
The avonbar cam can certainly be added to your standard engine. I would definetly recomend getting it timed in properly though, i personally prefure vernia adjustable timing chains. (if i recall correctly it requires 110/108 degrees on inlet 1 after tdc)
Edited by SumpNut on 17th Apr, 2005. |
18th Apr, 2005 at 02:11:19pm
It will make more power than the standard cam for the boost that you can throw at a standard / mildly modified engine for sure.
