Home > For Sale > Hybrid Turbo
Johnny
Member #: 6926
Accrington
Located in Accrington BB5 area.
im looking for £300 inc postage ONO
i bought this from a member on here about a year ago and its seen about 10k miles since (new/rebuilt)
aparently its a t2 from a ford of some kind and the compressor side is from a renault. not sure about which one it is but i know that this is a direct replacement for the garret t3. This is basically a bolt on upgrade from the t3. the ex manifold has been modified (believed to be done by one of the turbo gurus on this forum) along with the exhaust elbow to match them to the same location as the t3 parts. This turbo is still in excellent condition and with my engine it used to start spooling quite low down compared to the t3. and gives some good power. i was running 14psi of boost and got 163bhp @ 5,200rpm and 155lb torque @ 4,800rpm. the rr guy did not run it upto higher revvs due to him not having sufficient cooling on the engine so we only took it to 5,200rpm. he estimated it to have about 180bhp at 14psi.
What you see in the picture is what you get, inc the jubilee clips. the stainless hose was custom made for me.so that it fits onto the old t piece you get in the braided oil feed kits for the t3. and the oil return fits in the same place, the only modification in the water cooling for the turbo (you must use it) i have left on the fittings that i used to make it easier for whoever buys it. when i bought this i paid £350 for it and had to get the other various parts for it aswell which cost approx £70. if you want, i can throw in an exhaust downpipe with a welded in lambda bung too for free. (used but has life left in it).
Thank you JC.
http://i185.photobucket.com/albums/x28/joh...MF/IMG_0076.jpg
http://i185.photobucket.com/albums/x28/joh...MF/IMG_0078.jpg
http://i185.photobucket.com/albums/x28/joh...MF/IMG_0077.jpg
Johnny
Member #: 6926
Accrington
now on ebay
http://www.ebay.co.uk/itm/180755715677?ssP...9#ht_500wt_1413
I'd be interested in maifold & elbow if you fancy splitting. I have a hybrid t2 already. *smiley*
