Home > Wanted > Turbo Parts
custodia
Member #: 9675
coventry
Hi guys
Looking for parts to complete my turbo build.
I already have a t2 turbo, mirage manifolds, large intercooler with all pipework and a couple of gearboxes and am modifying a dellorto dhla40 for turbo application.
Basically im after a standard bore turbo engine that i can strip, bore to 1293, upgrade and rebuild.
cheers
Tim
I am located in the west country if that helps.
Don't bother with a turbo engine for that, waste of money. Just get a standard 1275 and rebuild it. The only upgraded bits in the turbo engine are the pistons (which you won't use) and sometimes the crank, which would no doubt need work.
Welcome to TM by the way *wink*
custodia
Member #: 9675
coventry
wise words and thankyou for the welcome.
In that case i am now after any 1275 engine. let me know what you've got so i can give this the power it deserves.
Tim
TrialsLife
Member #: 6752
Caerphilly, South Wales / Plymouth
I've got an A+ 1275 out of an SPI sitting here, had roughly 80k on the thing till it was yanked out of the car (previous owner wrapped it up!)
Let me know if your interested. :)
SurfToLiveLiveToSurf
Member #: 748
Cirencester, Gloucestershire
I have a worked Morspeed turbo head if your interested. has done about 3 miles. double valve springs.
1310 - Supercharged 16v Twin Cam - 190BHP - SC Built.
1293 - Turbo 16v Twin Cam - Build Commenced
