Home > Help Needed / General Tech Chat > runs and dies
flossy
Member #: 522
starts and runs ok on idle but when you try to pull away engine dies. when plenium chamber removed engine runs fine.
thanks in advance
dunno if it causes this problem but..
are you using the correct carb to plenum gasket?
the type that has the extra hole in it, or is it on the right way around. look at the plenum face and check that none of the holes are covered by the gasket, if they are cut in out with a sharp knife
Nick
Member #: 154
Midlands
is the carb definately plumbed up properly, and the pipes that need blocking off are properly sealed? sounds like the same problem i had when i first did mine.
as long as your carb/plenum gasket is the right one and your carb looks like the pic below it should be fine.
flossy
Member #: 522
had a look this morning gasket has six holes in it + center hole so does'nt mater whot way around it goes, and pipes plumbed in same way although throttle spindle is on the other side (not turbo carb will this matter) thanks.
Nick
Member #: 154
Midlands
yeah it will matter, it needs to be a sealed carb. 2 ways round it are getting hold of a proper turbo HIF44 or i'm pretty sure you can rebuild yours to turbo carb spec, have a search of the site i'm sure turbodave did a write up on what needs doing somewhere.
GUARANTEED your flaor chamber is open to atmosphere.
Will find a pic.
Edit:
Here you go.
http://www.turbominis.co.uk/iain/up/hif_mods.jpg
You can also connect pipe 7 into the pipe between the top of the regulator and the plenum chamber using a tee-piece if you wish - but I'd block it off first and see how that goes.
Edited by turbodave16v on 18th Apr, 2005.
Yes. You either need to get hold of a proper turbo carb, or modify yours to pressurise the float chamber.
Just to clarify - The standard carb will presurise the float chamber with the plenum and correct gasket - but it needs the pipes indicated sealling!
You might want to put some kind of sealer between the dashpot and carb body aswell.
Don't forget to swap out the needle - or modify yours aswell...
If the internal passages are clear.....I messed about with a NA carb for a bit, and although the drilling was there, as it had not done anything in 15-odd years since it was drilled it was gummed/varnished up and blocked solid!
flossy
Member #: 522
the pipes are blocked of as in the picture how do i mod the existing needle. also where is the hole that could be blocked.thanks (sorry for being a pain in the arse but my misses is doing my head in as its her car)
Edited by flossy on 19th Apr, 2005.
Just block pipe 8 and connect pipe 7 to the signal line between plenum and regulator.
You really need the 'turbo' needle and spring.
Iain will sort these out for you - or contact Burlens directly.
there should be an odd hole on the one side with no partner on the other side!! so it will matter
