| Home > Help Needed / General Tech Chat > verto to pre verto clutch probblems. any ideas? | |||||||
17th Nov, 2011 at 02:13:55pm
Hi, I built my engine and transmission up some time ago on my car rebuild. I have gone from spi to turbo/carb. We have got the engine running nicely. However, there is a problem engaging gears. I have changed the clutch from standard verto (when running spi), to a pre verto setup. I have a minisport ultralight flywheel and grey diaphragm.
17th Nov, 2011 at 02:33:33pm
We did with the van. Ended up needing a bent clutch arm for some reason. Also double, triple check your clevis pin is in good condition. Also sounds to me like either the adjustment it out or it isn't bled properly. If something is worth doing, it's worth doing half of. |
![]() 2057 Posts Member #: 9252 Post Whore Cleethorpes |
17th Nov, 2011 at 02:39:02pm
Done now needs redoing lol |
17th Nov, 2011 at 06:36:41pm
thanks for the input. we will be changing the clutch arm next.
17th Nov, 2011 at 06:38:31pm
17th Nov, 2011 at 09:27:19pm
i will have to get the arm off the housing and have a look. our thoughts were that the ball on the end of the arm may have had exessive wear, |
22nd Nov, 2011 at 10:44:57pm
the plunger was siezed into the bell housing |
23rd Nov, 2011 at 07:54:35am
