| Home > Help Needed / General Tech Chat > Rich Running and Flooding and restart problems with ERA Turbo | |||||||
![]() 270 Posts Member #: 69 Senior Member Coventry |
17th Apr, 2005 at 10:25:16pm
Hi |
17th Apr, 2005 at 10:57:22pm
sounds similar to what my car was doing
17th Apr, 2005 at 11:01:04pm
The needle valve could be stuck open or very worn. Try removing the live wire to the fuel pump, now start the engine and run it until it until it stops {uses all the fuel in the carb}. Now turn the fuel pump on and allow it to fill the carb. I found this wash of fresh fuel usually cleans the dirt off the needle valve and allows it to seat, if this is the problem .....
17th Apr, 2005 at 11:02:53pm
May be on a normal one on my roof chopped turbo its easy enough, this ERA has air con and fuel tank vent returs via carbon cartridge under the bonnet like the injections, space is lets say....errr limited...
17th Apr, 2005 at 11:04:12pm
have to take the fuel pipe of the carb everytime I want to start it unless its been sat a couple of days.
17th Apr, 2005 at 11:08:22pm
yep, thats exactly what i had to do
Edited by Nic on 17th Apr, 2005. |
17th Apr, 2005 at 11:14:09pm
yes how do I post them.
18th Apr, 2005 at 09:33:04pm
also could be the choke seals gone hard and leaking or the choke arm hitting the heatsheild and not returning
![]() 966 Posts Member #: 358 Post Whore Snetterton, Norfolk |
18th Apr, 2005 at 09:40:24pm
u a bit of a mini fan then skolawn? And repairing the one is enough for me let alone 8!!! |
18th Apr, 2005 at 11:27:51pm
Yup bit of a mini fan, bit of a problem I just keep buying them, forgot about red shed my 72 GT in round nose shell and black 1980 GT project the deseamed shell and a mini 1000 I have stashed somewhere..
